Steering Wheel Controls -> USB question
  • Steering Wheel Controls -> USB question
    Hey guys, I found this part online and had a question about it. My
    plan is to completely replace the head unit in my car with a computer,
    so I was wondering if I could still use this part even after removing
    the head unit. Basically my question is that whether the adapter is
    receiving its signals from the steering wheel or from the head unit..
    If the head unit is gone, will the buttons on the steering wheel still
    work and send a signal to the adapter?
    http://indashpc.org/new/adapters/car2pc-maz.html
    Thanks in advance!
    @timebandit
    i'm wondering the same thing. you may want to look over here it seems that with the right wires soldered in may provide the results we are looking for...
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
      I couldnt really find anything useful there related to our problem.. I might order it, plug it in, and see the outcome.. Because im SURE that there are many people out there with the same question.. Either that or email the vendor and see what he says..
      EDIT:
      Just emailed vendor, hopefully will get a response soon!
        Got an answer!!
        Hi,
        Our device works only when OEM headunit present,
        Hope this helps,
        Dmitry/
        -----Original Message-----
        Sent: Thursday, September 17, 2009 11:02 AM
        To: [email protected]
        Subject: customer from Car2PC WebPage
        Hi,
        I had a question about your product.
        My plan is to completely replace the head unit in my car with a computer, so
        I was wondering if I could still use this part even after removing the head
        unit. Basically my question is that whether the adapter is receiving its
        If the head unit is gone, will the buttons on the steering wheel still work
        and send a signal to the computer?
        Thanks!
          i would recommend this...
          http://www.rcjoycon.com/base_3/menu_...om_board_idx=9
          i use it in my 2006 mazda 6.
          i have the audio steering wheel controls mapped to it.
          it supports up to 10 buttons.
          i paid $32 . money WELL spent.
          you will have to locate the two wires that run from the steering wheel to the radio, hijack those and tap them into the joycon.
          do some configuring , and presto.
          trinybwoy
          2006 Mazda6 Carpc
          2008 Acura TSX Nexus 7
            Hmm.. That seems interesting, I have a few questions though..
            1) Does there have to be a Software running in the background all the time?
            2) How do you map the keyboard to centrafuse? Does centrafuse have "keybaord shortcuts"?
              1) no 3rd part software is running . the device identifies itself as a usb Keyboard.
              2) (a)to program keys into the device , you will use the bundled software. (once the keys have been programmed, u can exit the software and never use it again. until u want to reprogram.
              (b) yes centrafuse has kboard shortcuts.
              you can assign up to 3-4* keystrokes per "key" pressed.
              eg. i have the volume down button on my wheel mapped to "control-alt-delete"
              i have the volume up button mapped to "alt+tab"
              etc...
              trinybwoy
              2006 Mazda6 Carpc
                AAH alright.. makes total sense.. Another question for you then, where ALL the buttons on ur Mazda-6's steering wheel coming down to a single socket? in which u plugged this into? or did you need more than one of these to map ALL your buttons on your steering?
                  all the buttons came down to two wires that connected to the back of the radio.
                  if i remember correctly, is a black and a green wire.
                  it has been a long while since i have been at the back of the radio.
                  i will look for some mazda radio wiring for u.
                  wut model car do u have?
                  trinybwoy
                  2006 Mazda6 Carpc
                    Im actually driving an 04 RX-8.. All parts for my CarPC are here and im hoping to get some setting up done this weekend.. But now that this item has arrised, I might be waiting another week to get it setup with the system too.
                      http://forum.mazda6club.com/index.ph...=post&id=27164
                      u will have to register on the forum in order to see the diagram .
                      the color of the wires are actually red/black and green/white.
                      to view other wiring diagrams for mazdas check out post #2 here...
                      http://forum.mazda6club.com/index.ph...&#entry1070225
                      trinybwoy
                      2006 Mazda6 Carpc
                        dude - that sounds amazing!!! i have a cadillac CTS and i think i know which wires are for the steering wheel. Would it work on my car? Could the website help me if i run into problems?
                        Now it is recognized as a keyboard - i would like to control the volume and mute. Is this feasable?
                        Also the link shows the product - but how do i buy?
                        thanks again
                        AD
                        Atom - 1.8ghz
                        2GB Ram
                        32GB SSD
                        8" TouchScreen
                        Finished Project
                        Car Hacking
                        WorkBlog
                        Video
                          great! i just registered, looking forward to the diagrams.. Do you think they are the same for all mazdas?
                            Hey afterdigital, you can order them on ebay from here.. Ill let you know how it goes when I plug them in.. Would really appreciate it if you could do the same!
                            http://cgi.ebay.com/CarPC-JoyCon-Ste...ht_4044wt_1165
                              thanks again
                              AD
                              i got mine from ebay.
                              it will work with any steering wheel buttons/or any buttons that operate using resistive current.
                              if you can map a shortcut key to mute and volume it will work.
                              i know if u use 3rd part apps such as winamp and centrafuse, it will work.
                              the gentleman who sells them is VERY helpful!
                              customer service is top notch!
                              simply email him and he will respond very quickly
                              trinybwoy
                              2006 Mazda6 Carpc
