Lilliput EBY701 usb disconnecting windows 7
  • Lilliput EBY701 usb disconnecting windows 7
    so ive run into a problem with my brand new Lilliput EBY701 double din rdy screen i bought and just received from mp3car store today.
    when i plug everything in on my laptop it keeps flashing the screen on and off and the usb connect and disconnect keeps sounding... i was wondering whats the solution to fix this issue. since i was gonna test it out before i actually put it in my car. I have searched the forums and cant find a solution to this
    im using windows 7 btw
    thanks, tauzins
    i ran into this issue a few days ago when upgrading to windows 7 too.
    i found out i had to uninstall my nvidia drivers, and instead use default windows drivers for my video card and it would work =\ must be some sort of conflict
    hope this helps!
      i looked into it... apparently my laptop the 6150go drivers are ****ty from microsoft... i used custom ones and it works fine
        Little off topic - Whats the real difference between the EBY version and the Lilliput GL629-70NP ?
        Also does the EBY ver auto switch for reverse camera?
        New Car PC Build list in progress
          Glad to see others had the same issue and there is a solution. I just tested mine out and I was like oh no hope I don't have to send it back.
          I have a NVIDIA GeForce Go 7900 GS. Will have to stick with default windows drivers then when I put it in my car then.
          2007 Ford Focus
          Project Page
          Software - Win7, Centrafuse, Firefox, MediaMonkey, Trillian
          Hardware - Intel X25-M 80GB SSD , VIA C7, Jetway J7F5M-VDE, Kingston 1GB RAM, Preassembled 2Din Frame w/7" Lilliput EBY701
          Planning: 85%
          Parts: 95%
          Install:75%
