Windows 7 Gestures with Lilliput Touchscreen?
  • Windows 7 Gestures with Lilliput Touchscreen?
    Has anyone gotten the native gesture support to work with the lilliput touchscreen?
    I am very interested in getting this to work, i would actually go out and buy another touchkit that was surely supported but since i have an antiglare/sunlight readable lilliput i cant just replace the touchscreen. I can however replace the controller with another 4 wire type (i think)
    Has anyone gone down this road before, i am looking for a little advice
    Thanks in advance
    Resistive screens are much harder to gesture on, so your letters end up taking up the whole screen. Not sure how that effects win7 gestures.
    openMobile - An open source C# Front End (why choose openMobile?)
    - Always Recruiting Developers -
    Like what you see? Donations are always welcome
      I remember looking into it. When I first installed Win7, my lilliput touchscreen was recognized as a "Pen & Touch" (or something like that) device. But I could never get it calibrated. I would touch one place and the mouse would be somewhere else. Plus I think the x and y axes were mixed up or something. When I installed the lilliput drivers (TouchKit), it wasn't a Pen & Touch device anymore. Briefly tried searching around and found nothing. I'm also interested if there is a solution. It would be great if it did work.
        i was going to say exactly all of this
          ditto
          TruckPC - gutted, being used for test setup
          BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
          BlazerPC - Nexus 7 with Timur's USBROM
            I found a few links you guys might want to check out. I plan on trying some of the suggested things.
            Even though this is for a different touchscreen it references the drivers below and a calibration utility called CalTouch (i couldn't find any drivers by searching "Caltouch")
            http://forum.eeeuser.com/viewtopic.php?id=62029
            HIDUSBTouchDigitizer driver at the bottom
            http://www.tvielectronics.com/Touch_...Downloads.html
            Apparently you need some additional software to calibrate ("CalTouch") if anyone can find this i think this may be the key
            Also this website was helpful
            http://spekxvision.wordpress.com/200...ith-windows-7/
            I think we can find a Windows 7 or Vista Digitizer or tablet driver and then use the caltouch to calibrate and we should be good to go
              So here is a direct link to drivers listed in the second link above.
              http://shop-on-line.tvielectronics.c...hDigitizer.zip
              I tested these last night by
              uninstalling the current touchkit
              rebooting and verifying that windows has not installed the touchscreen drivers
              then i installed these drivers and i now have the control panel icon "Tablet PC" and i can use "flicks"
              I should mention that i did do this after an upgrade install but it shouldn't make a difference becuase i still had the touchkit application and drivers installed
              Good luck gentlemen
                CalTouch download
                Great find! I was looking how to activate the Windows 7 Gestures. From your eeepcuser link, there is now a download available for CalTouch. Are you using that too with the HIDUSBTouchDigitizer?
                CalTouch
                  cooool. will try now.
                    awesome...gotta try this too
                      Just tried it and it works great. Thanks antimatter!
                        ugh, my luck i guess. i uninstalled, installed these drivers, all went smooth. even calibrated fine, and seems to work fine but the entire upper right quarter of the screen is whack. the cursor is all over the place when i touch that area. the flick guestures did not work at all either.
                        back on lilliput drivers..
                          @ all
                          No problem, glad to help
                          CalTouch
                          It seems that the HIDUSBTouchDigitizer drivers are the caltouch drivers since that was what the icon that get's installed says. I will have to check the driver version to see what is newer. I tried to dowload off the the first link but RapidShare sucks!!!. I will post the driver version after lunch here
                          @trader
                          Did you try the rapidshare link ?
                            antimatter,
                            When running the setup.exe from the download link it appears to be for XP/Vista only. The download page at http://www.tvielectronics.com/Touch_...Downloads.html does have a Windows 7 package available but this appears to be the same that is available from the eGalax website, which appears to be an updated version of what's available from www.touchkit.com. Can you please confirm which one you were able to get working with your Lilliput and Windows 7 Touch?
                            Thanks,
                            Joe
                              For what it's worth, I installed the "Windows XP/Vista (Tablet Edition)" - http://shop-on-line.tvielectronics.c...hDigitizer.zip
                              I'm running Windows 7 and have a Lilliput EBY701 and the flicks work. I didn't know there was a beta Windows 7 package, but I don't think I'm going to try it. I'm just guessing that it will not make the screen a pen and touch device.
