Radar Detector Location Question.
  • Radar Detector Location Question.
    Lets say Bobert12 doesn't live in a 'radar friendly' area.
    I want to buy an STi Driver, but the only location i can put it, where i will have visible access to it, is pretty much under the dash.
    Im not to sure if this would be a wise choice.
    Like its easy to think to top the line, this sucker can pick up a signal from almost a kilometer a way, location in the car shouldn't matter. But if you put something in the way of the signal, then it could really screw things up.
    And by under the dash, i mean there would be the windshield and a few peices on plastic in the way. ( Hopefully not the firewall)
    Im curious if it would be even worth my time? Or could i get away with it with minimal consequences?
    Thanks!
    it'd be a waste. The radar detectors pick up mostly by line-of-sight. You'd be really hampering their abilities.
    I think there are a FEW radar detectors that actually utilize a separate detector module that you can stick up on the windshield somewhere inconspicuously and don't look like detectors at all. look for em.
    Also, usually in radar detector unfriendly states/areas, you'll have the cops running radar detector detectors... which will mean that unless you get a good detector that can block or stealth mode itself out of the detection from the police detector detectors, you'll be screwed no matter what.
      You need one of the superheterodyne non-detectables. (Did I spell that ancient word correctly? DSP is so much easier!)
      If you use a detectable, you could use my method.... detector in the front (mine in a vent behind headlights with forward line of sight), extended panel & controls and power switch (settable to off-on-detect), and a microwave resonator in the passenger seat - powered (say) by an inverter that somehow happened to accidentally turn on just now(ish).
      You could also use certain radar-style circuits with appropriate IF frequency(s), but I love watching them scatter when (with the resonator) I say "oh ****e - it's still on!".
      PS - my experience is that if they "detect" you have a radar detector, they will rip your vehicle apart until they find it.
