Anyone tried hooking up a notebook touchpad?
  • Anyone tried hooking up a notebook touchpad?
    Something like
    this?
    or this?
    not quite sure why you'd even want to bother when Fellowes makes one like this or this.
    Or
    and
      I use the first one ddt posted.. works great.
      aka Kumaneko
      "Don't make me moderate your ***!"
      Maxima of Doom - project thread - photo gallery
      mp3car system is currently FUBAR and finances do not allow for a correction of that situation
      Real computer hackers use a rotary cutting tool on their motherboard.
        I am in the process of building my system, and I am using the same touchpad you have a link for. The one for the compaq armada. all you realy have to do is figure out the pin outputs for it and connect it to an ps/2 port and it works without a problem. The reason I got this touchpad is because the plastic molding around the touchpad is just like the plastic molding in my car. I plan to mount it in my console for that stock look
          I have the same spare touch pad off my notebook. It would be nice to say buy a $2 usb cable and wire it in somehow...
          Mine needs to be updated.
            IBM style Trackpoint
            Rather than using a touchpad, I prefer the IBM style TrackPoint ...
            Of course, rather than try to destroy an IBM laptop, I figured, this would be an easier install: Trackpoint
            Figured it would be nice to include a picture :-)
              i also have a copmpaq touch pad module wich would be great to find a pin out for
              WINNER!!!!
              run-on sentance comp 2002!!
                Re: IBM style Trackpoint
                Did you get it to work yet?
                2000 Grand Prix GTP
                667 mHz PC | 512 PC 700 | DVD | ATI All-In-Wonder | 100 Gig HD | 7" LCD
                  Re: Re: IBM style Trackpoint
                  I've got it working in a test environment ...
                  I don't (yet) have it working in a live environment, since I'm in the process of replacing my truck ........
                  @shley
                    What about wiring the trackpad to a serial port? My SBC only has 1 PS/2 port and then 1 or 2 serial ports.
                      Sorry about the revival of such an old thread but i was wondering if it would be worth me getting my hands on a trackpad from a bettered notebook as i had aspirations of setting one into a nice surround on the dash
                      how do you go about wiring the thing up, does it essentially have the same wiring as a PS2 mouse for X/Y co-ordinates and 2 mouse clicks?
                      www.streetrace.co.uk - The UK's best modified car club (With lots of 16/17/18 year olds for scouse to abuse)
                        usually yes, the wiring is the same as a ps2 mouse, i've hooked up two, however i know some people who have messed witha couple and could not get them to work....dont know if they were doing something wrong
                        PC Components:
                        My work log
                          Thats sweet then, will it be using all 6 PS2 wires so i could just have off the cord to an old mouse, get the soldering iron out and e'voila ??
                            i believe only 4 pins are used, a power a ground and 2 datas, not sure of the exact details
                            PC Components:
                            My work log
                              i am planning on including the trackpads control buttons so the other two will be left and right click
