Using two touchscreen panels?
  • Using two touchscreen panels?
    Does anyone know that if I can install two touchpanel one on top of the other?
    Such as this: linky
    My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
    Why would you want to do that? Each touchscreen layer also decreases brightness noticeably.
      What do you think you would accomplish by having two touchkits?
      How about the Wiki?
        You can but it wont do anything. There will always be pressure on the "back" one, so it will constantly read something false. And the front might have the same problem, especially if you try and squeeze it in the OEM casing.
        Like DP said, what are you trying to accomplish?
        1.9in x 2.9in -- 47mm x 73mm
          Only logic I can think of is that one is broken and instead of taking it off he rather just put one on top. The other reason is maybe he is adapting a OEM screen to use with the car pc but wants to be able to switch betweeen OEM and PC? If its anything else then I have to ask the same question, why?
          1X Ainol Novo Flame Tab
          4X MK808b
          3x Perixx Touchpads
          3x 7 inch Screens
          1X 7 inch motorized Screen
          1x Win 7 PC
