Is there any special 'pen' to use on touchscreens?
  • Is there any special 'pen' to use on touchscreens?
    I was just wondering if there is anykind of special pens such as the ones used on the palm pilot and pocket pc's. Reason is sometimes I wanna use the onscreen keyboard and I would think my fingers are too big and would hit 2 or 3 keys at once.
    If you want one it's called a stylus.
    http://www.styluscentral.com/
      sometimes I use a pen. Just make sure the tip is not sharp so that you dont scratch the screen.
      Mine needs to be updated.
        A stylus only works for touch resistive touchscreens. If your touch screen is heat sensitive, your out of luck. You'll probably never bump into a heat sensitive t/s for a carputer
        Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
        Better than winamp. Click here for qcd player.
