Help! Airboard!
  • Help! Airboard!
    I have this airboard hooked up to a laptop right now (I'm STILL in planning stages) and I have 2 problems with it that I was hoping you guys could help me with.
    1.) Mouse will not work. The reciever shows "data" is being recieved, but the PC does nothing - where to look? What to change?
    2.) The software (Airboard Manager) will not let me customize the hotkeys in an easy way, how do you reccomend I change thier bindings?
    Thanks!
    Re: Help! Airboard!
    Thanks!
    If you have connected the mouse via a PS2 convertor thats where your problem is.... I had the same issue. Connect though the com port and remove ( not disable ) the LT mouse - should pick it up as a standard mouse then...
    Terran
    My Project Site
