USB Hub Malfunction?
  • USB Hub Malfunction?
    Hi all,
    This is probably more of a general computer question, but since it happens on my carputer I figure here is a great place to start.
    I have a bunch of USB devices in my rig. The PC is in the trunk and I run 1 USB cable to the dash where I have a USB hub. The hub is powered of my pc power supply so its getting 5V when the car is on. However, I keep getting all sorts of random errors with the hub. I have tested each and every device separately in the onboard USB ports and everything works perfect. However when I connect the devices (GPS, touchscreen, etc) to the hub I get "usb device has malfunctioned" or "windows cannot recognize your USB device". This is annoying the &*#@ out of me since whenever this happens, the carputer is rendered useless as I cant use the touch screen. I am at a point now where I am thinking of once again taking the seats and carpet out so I can run dedicated USB cables from the trunk to the front for each device. Before I do this I figured I would see if anyone else has this problem? This is also my 2nd hub (as I thought the 1st might have been faulty) and about 6th different cable I've used to connect it.
    I am running Win7 x86. Any ideas????
    Thanks!
    It's a power problem.
    A usb port can only put out 500mA.
    A usb hub uses roughly 100mA.
    That leaves 400 mA for the devices.
    Run dedicated 5 volts to the hub's power input if it is a powered hub. If not, get a powered hub.
    It's usually a good idea to run a dedicated USB cable for the touch screen, that way no matter what happens you can still control the screen.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
      something like that...
      he said that it is getting power from the 5v rail of the power supply, but neglected to mention if he has tried 2 of the same hub, or if they are powered externally from the power supply(the mention of getting power from the 5v rail leads me to assume that it is a externally powered hub)
      if you have tried 2 of the same model hub, you might need to try a different model/brand hub to resolve it.
      also, i second the idea to run a secondary usb ext. for the touch screen control-- that way, you can at least still control the pc..
      otherwise, i am told that the car-specific powered hub in the mp3car store works very well with very little issues.
      next project? subaru brz
      carpc undecided
        I am powering the hub off one of my psu 5v rails so it only gets power when the mobo is powered (it is externally powered). I have also tried 2 different brands of hubs.
          how long is the wire run? What guage wire? Use a multimeter... is 5 volts really making it to the other end of the wire? Is the USB cable shielded? Try messily running another USB cable through the car above the carpet for a couple days to test. Does that eliminate the issue?
