What if I run Mediaengine as a shell? Touscreen still works?
  • What if I run Mediaengine as a shell? Touscreen still works?
    Will the touchscreen still work (digitalww 7" usb) if I run Media Engine as a default shell? Only reason I am asking because I know that windows has to load up the touchscreen prog (in the tray) for it to work and if I close the prog, the touchscreen will not work anymore.
    I would think so.
      he will need to go into registry and add that driver to the runonce or runatonce section. make it the first thing that loads on the list
      abcd-1
        works anyways. just load to windows to calibrate it first, then you should be ok.
