Turn on front camera
  • Turn on front camera
    Is there a way to turn on a front mounted camera when my monitor switches from PC mode to one of the AV modes that the camera is connected to?
    I don't want to have it powered on all the time.
    a better question might be why you have a camera mounted to the front of the car..
    you should be able to connect the camera to a switched acc line-- that way, it will only be on when the car is on.
    next project? subaru brz
    carpc undecided
      The front camera is there because I find it near impossible to judge how close I get when parking etc.
        I only want it powered when I'm about to use it
          then you'll need to use a switch..
          carpc undecided
            Usually mounted cameras do not consume much power so it's easier to just leave them on when the car is on (i.e. powered by the PC power supply).
              i use my front mounted camera for when i'm on the race track to record
              New Car PC Build list in progress
