A new camera setup
  • A new camera setup
    I have been working on some truck cams for a client and have found these little metal cameras, they are about 3/4" square maybe 1" high. They to mount down and have an amazing video quality they have the 1,2 and 3 meter lines, the cable lengths are excellent for power and video. I am using as side and rear cams with this 3 screen monitor/mirror. the 10" monitor/mirror is top quality and has 4 video inputs 1 is switched to be for reverse cam. if you need links just ask SNO
    are they waterproof?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
      yes the front where the lens is, bottom looked iffy to me as the 4 small screws show so I wiped the bottom with silicone just to be safe they have been on the outside of a transport for the past 3 weeks travelling across canada (mostly northern canada) driver says they are perfect, not affected by extreeme cold and he says great night vision
        Yes, give link please. Thanks.
          hmm.. i mean really really waterproof. i want to put them on the side of my boat trailer which will get submerged ~1 meter or so
          M10k
          My Car Pc Install
          My Boat Pc worklog
            lol well i can't say that waterproof, the wires come out of the center of the bolt so that would leak for sure without silicone. now maybe if the camera bolted to the trailer light housing might be enough to seal the wire opening, also the harness is small and the junctions might need sealing as well . buy one and see. only 25 bucks + shipping
              may be worth a test. link us up
              M10k
              My Car Pc Install
              My Boat Pc worklog
                I'd love to get the link for both the camera, and the screen unit too.
                Those look pretty awesome, would be great for mounting on the back of my SUV, as I can't see my trailer when I'm towing (trailer is narrower than the car, so its invisible!).
                Plus having those instead / as well as wing mirrors would be wicked, and side mounted camera units for pulling out of side streets like the new BMW's have!
                The mind boggles
                  link please, this would save me a lot of time in relation to a cam install
                    the camera I picked the qv9750 in dropdown list and used upgraded shipping here are the links that I was sending out via PM
                    cameras http://www.aliexpress.com/product-gs...olesalers.html
                    monitor http://www.aliexpress.com/product-gs...olesalers.html Hope this helps SNO
                      just to add to this thread. another source with a ton of cameras:
                      http://www.camera2000.com/
                      M10k
                      My Car Pc Install
                      My Boat Pc worklog
                        Very cool cameras and monitors!
                        I'm curious about CCD cameras...any recommendations?
                        ---------- Post added at 01:26 PM ---------- Previous post was at 11:55 AM ----------
                        Found this one for $49.00 (previously $199); CCD, great reviews. I would use it behind the front grille, but I'd like the ones posted in the OP better for the side/rears. But I can't find the specs for them.
                        Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
                        Skin: MetroSex on the Beach preview
                        07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
                          Do you know if the PC1030 image sensor is worse or better ? Google isn't really helpfull on that one :-/
                          // Per.
                            Bought one of these monitors, the user manual does not describe anything regarding "programming" the monitor.
                            It seems that it defaults to AV4 / AV2 when the green wire (backup cam) is activated... Regardless what i set it to with the "Mode" button on the remote or on the front glass. Pretty stupid.
                            I want it to display three video inputs, or even a single one, but two isn't what i wanted....
                            // Per.
                              just in case anyone wants anupdate here is alink to hte cameras http://www.aliexpress.com/product-gs...olesalers.html
