PowerMate Controller
  • PowerMate Controller
    anyone use/try this thing out? i was surfin around tonite and came across this device and the guy said he used it for a carputer... and this thing works in Windose too, im goin to head by a Mac store tomorrow and see if they have one there, and see what it costs too. hers a url for it also PowerMate
    power mate
    http://www.digitalww.com
      thanx for the kik in the azz digital, i wasnt using the search function as usual...
        No problem I have one myself and it is a great gadget.
        Armen
          How can you program this thing to run everything?
          The site tells you that it can raise the volume and also be programmed to do everything else.
          How do you switch between functions, isn't it just ONE KNOB and nothing else?
            It just applies the commands to the selected window...Not bad if you plan on having only one app open at a time.
            Aura MR62 (F and R)
            My Current MP3s
            IamDefiler.com
              Highly recomended. At very least it looks cool.
              2002 Golf TDI With Phatbox . Blue 87 Supra Needs to go, Grey 89 Targa with stock Radio.
                I've got to get a hold of one, because I still don't get it.
                How does a scroll knob and a push-down click function know what you want to select?
                Do keep turning the knob until it lands on the button you want and then click?
                It states that you can program it with any keyboard function(unlimited). So how does it know what keyboard function I want to use if it only has one knob?
                It looks nice but I'm still lost on this one...................
                  It's in the software...
                  You select the app. (.exe) to apply the commands to, then select the action (turn left, right, click, push and left, or push and right) and apply the key command to each action...
                  Aura MR62 (F and R)
                  My Current MP3s
                  IamDefiler.com
                    Just my luck... where i live, no one carries the controller. so now i go huntin for a used one or sumthing better, if i can find sumthyng better
                      You have to order it from Griffintechnology
                      Anyway I bought it and I'm a bit disappointed with the long-click and click-rotate functions. Basically if you push and rotate, it'll do the 'click' function or 'long-click' (If you took too long to rotate) no matter what.
                      So say in winamp, if you set rotate to volume, click to mute, press-rotate to scroll through playlist, and long-click to play track.. then anytime you try to scroll through the playlist, you will *always* either mute or change tracks when you let go.
                      I emailed them asking if there was a way around this that I didn't understand and received no response.
                      The controller itself seems quite neat and well built, but it doesn't seem like the click and long-click are usable in combination with press-rotate. You have to pick, either or.
                      Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
                      Car: 1993 Nissan Maxima, Black Emerald
                        agreed
                        I have the same problem...hopefully they will update software for this, as well as adding double click
                          I'm thinking about getting one of these.... which means you might see media engine support for it one day.
                            not like i would be that hard to support....all it does is send keys
                              yes, but to support it without installing the griffin software and to be able to control all functions of the program exclusively with the powermate.
