cameras and pc integration
  • cameras and pc integration
    I'm not quite sure where I'm headed with this one, so bare with me please...
    I've seen installs where both ideas have been done, but not really together. This is all a futuring plan I intend to do when money starts building back up (spent too much on build so far).
    So, here goes... I'm going to want cameras: reverse, dash, inside, etc. I have a 7" lilliput ts with reverse wire/input for auto switching which I intend to use as well. However, I would like all the cameras to be able to record as well, to the computer if possible.
    I'm not sure where to start with this. Do I get rca enabled cameras, and run/split the signals to the computer using those rca->usb devices? Would this still record in realtime? Would this be feasible for 3 or more cameras, or would I have to use 1 rca->usb device per camera (upping cost/power significantly)? Depending on frontend used, would they act like "webcams" that could be viewed or would they not know they are "cameras" and see the rca->usb device only?
    I also read about xport (i think), that could split gps signal. Is that feasible to split and overlay for multiple cameras though? I know, lots of questions, but fresh in my mind.
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
    I've thought about this too but that's as far as I got. I thought about also having the timestamp overlaid onto the video. The thought there was about being used to prove the other guy was the idiot and that he ran the stop sign, not me. if you know what I mean.
      The reverse wire on the Lilliput changes inputs to an RCA input.
      I see two ways of accomplishing what you want, neither of them is particularly "easy":
      1. Use RCA splitters to run the signal from the backup camera to both the Lilliput directly and to a video input device for the PC.
      I would think the only view you'd want to auto-switch is the backup camera. I could be wrong.
      You would need a video capture device that can record from a composite video signal.
      2. Use cameras that are designed for PC connection, usually USB. You won't have the auto-switch function on the Liliput, however.
      XPort only deals with a GPS signal, not video. I'm sure there is other software that will do this, but it's not my arena, so I can't help you there.
      How about the Wiki?
        You can accomplish your goals using either RCA composite cameras, or USB webcams, but both present unique challenges and slightly different capabilities.
        RCA - pros
        • Lots of cameras and mounts available.
        • Many made specifically for automotive use.
        • Fair to very good image quality
        • Better than webcam performance at night
        • Relatively low cost
        • Easy to setup auto-switch rear-view with many monitors and available the instant power comes on.
        RCA - cons
        • Require seperate power supply (more wires)
        • Require a dedicated capture card or device in order to record on PC
        • Capture performance may not be as good as webcams
        • Multiple cameras requires additional hardware support (multiplexer)
        Webcams - pros
        • Lots of selection
        • Plug and play integration with PC
        • Audio recording
        • With careful selection of software and drivers, very good recording quality
        • Reasonable cost
        Webcams - cons
        • Auto switch requires additional hardware (fusion brain, Arduino etc)
        • The camera isn't available until the PC is fully booted, so you have to wait before a backup camera becomes available.
        • Generally poor low-light/nighttime performance
        • Larger and more difficult to mount than some RCA cameras
        • HD cameras can be quite expensive, and require a LOT of processing power to record at full frame rates.
        Bottom line: Webcams are easier to get up and running/recording if you can live without the backup cam. A non-recorded backup cam is easier to do with RCA composite camera. RCA cameras are probably better suited overall to the auto environment, but require greater effort to integrate with your PC.
        Cheers!
        VegasGuy
          DP, yes, the only view to auto switch would be reverse camera. If we talk about rca cameras, this would be easiest to accomplish, and then just split the signal to the 'device' needed for the pc as well.
          On rca cameras, not really necessary for them to be available right away, except the reverse camera. If the webcams aren't going to give good pictures (especially at night), it might be worthwile going all rca. However, if the webcams are 'ok' at night I could live with that. The recording feature is just for safety and in case I ever need to 'prove' something (*knocks on wood*).
          Maybe I should think about an rca reverse camera, split to lili/pc and anything else being a webcam. This way I could retain auto-reverse on lili, or view any camera I choose to through a front end (depending), or through windows.
          I think the mixed setup looks ok to me, like a jack of all trades setup. Now, I did mention xport for gps stuff, could this be used for the webcam overlay with specific software (DP I know you said you're iffy on software), but in generality in case someone else might know this?
            I cannot tell what your running for a front end from your posts.
            Using Centrafuse, you can use the plugin Dashcam "DVR and WebCam recording for two cameras at the same time. Comprehensize text overlay and tons of customizable features", see link http://www.centrafuse.com/AppDetail.aspx?appid=118 and do a google search on dashcam for centrifuse for more info. You should check out sneck's posting here http://www.mp3car.com/show-off-your-...ech-carpc.html to see it installed, there is a shot of it running on on his LCD mounted in his dash.
            You can purchase a reverse camera to conn to your reverse lights and run a wire to the reverse trigger wire on a Lilliput monitor (so it switches to the reverse camera when the car goes in reverse) here http://store.mp3car.com/CMOS_Infrare..._p/com-105.htm.
            I would install the reverse camera to the lilliput with no recording, then install webcams facing forward in front of rearview mirror like sneck did, you can have other webcams in the deck of the back window recording forward or back, cameras pointing out to the sides (not using dashcam, unfamilliar with using more than 2 cameras).
            This way the backup camera is visable even if the PC is not booted up.
            Others using different front ends may have more information, you should post what front end you require the plugin for.
              I didn't really post what front end I'm using because at this point it wasn't that big of a deal. As in a previous post I mentioned "front end (depending) or windows" meaning viewing/switching/recording with cameras were not mandatory for a front end for me. Anyways, I'm using OpenMobile, one of the revisions from a couple months back, not the official 0.8 version. I've been developing on and off as well for it. I've tried RR, didn't get too used to the pro-longed out of the way customization (just my opinion so don't flame), had a centrafuse trial go untested cause my carpc wasn't in the car lol.
              Anyways, opinions aside...
              ^^^ That's the plan, still researching cams though.
              Why no recording? Just because it's easier to use the 'other' cameras for recording, so essentially 2 reverse cams, one as a webcam for recording, and the normal lilliput reverse cam?
              Not trying to get down on the informative posts, hope this didn't come across as mean toned...
                Look at it this way. Most of the time, the recording camera won't be started or recording when the car is in reverse, so it can't provide documentation in the case of an "event". All the rest of the time, it's recording a view that's not particularly useful. So it's money spent for something of little value. Not to mention the additional processor load it incurs. I can't emphasize enough that THAT is the biggest issue you have to deal with when running multiple cameras. As someone who's used multiple cameras for some time now, once the novelty wears off, you'll just find yourself using one high-quality front view most of the time.
                VegasGuy
                  i have toyed with this idea in the past..
                  if i go through with it, i have decided that i would run a standalone dvr. i am a camera tech, that works with pc-based dvr's every day, and imo, the pc is one of the weakest links in the system-- there have been multiple cases where our clients have missed something while the pc is performing a reboot cycle... the stand-alone boxes can also be a little glitchy, or have primitive menu structures, but overall, they have faster bootup times, and less parts--so less things to go wrong..
                  i also believe that cameras outputting a composite signal will give you more options overall then a usb camera setup.. the toughest part here would be to find powered splitters/multiplexers that work on voltages at or below 12v.
                  as for Xport--it is specifically designed to split data within the pc(i don't believe it will push the data to anything outside the pc), and really only Com port data, so 2 different programs can get the same data stream without overtaking the com port(the OS will normally only allow one program to access the com port at a time--xport becomes that program, and splits the data). i don't know of any cameras that would use the com port for video--- pan/tilt/zoom cameras use the com port for movement functions..
                  next project? subaru brz
                  carpc undecided
                    I didn't account for the additional processing become a huge factor, as I'd figure it wouldn't occur THAT much overhead, but obviously some. About the novelty, I can probably relate, but, as much as you say you'll be using a front view most the time, did you ever record the others or if you didn't, wish you had?
                    I didn't really want to use 'excess' boxes as I've already housed the pc in a compartment and didn't want things under seats (in winter it's hell with salt/water/mud/etc or to be accidentally kicked). If the dvr was placed and used, is it easy to get data off of it? I've never used dvr before, even for tv since I don't watch it, so not quite sure how it interacts with other equipment/users. Would adding the external overlay hardware create even more havoc? The overlay is probably a novelty thing as well I would think. Thanks for explanation of xport!
                    Seems like it's not a real clear ordeal. If the other views aren't really necessary to record, they might not be necessary to have at all then. I am always on the 'what-if' thinking, why I am discussing doing the 'above' normal situation. Hmm, at this point I think Soundman might be onto something with recording not on the pc...
                      most of the stand-alone units save files in 10sec intervals, and save them as standard video files(i don't remember the exact type of file, but is a very standard format), usually saved to a SD card.
                      this is one of the unit's i have been eyeballing:
                      http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
                      as you can see, it is a very small unit, but at $100 for a single input, it is a little pricey, and has very basic features. i was planning on using the secondary a/v input on my lilliput to see it..
                      this also has audio-- just be very careful with this. IL, VA, OR are all states that it is a very serious offense to record someone who has not given their express permission:
                      http://www.nytimes.com/2011/01/23/us...pagewanted=all
                      this is a much larger 4ch unit:
                      there is also this site that came through my spam filter a while back:
                      http://ideals.com.hk/index.asp
                      i have not contacted them to inquire about single/small orders, or price-per-unit, as i am not very serious about installing cameras on my car, and my company doesn't do anything with mobile dvr's..
                      but both of these units appear quite large compared to that first unit, and similar to you, space is the major limitation in-car for me..
                      carpc undecided
                        FYI, just checked the first link and it's showing as 79.xx + free shipping.
                        Eavesdropping law being "one step lower than murder" - LOL at that... Hope that never comes to PA. Thanks for links though and being descriptive.
                          Not trying to get down on the informative posts, hope this didn't come across as mean toned...[/QUOTE]
                          The Lilliput Monitor is and the Composite camera are instant on, If your nose first into a driveway or parking space,waiting for the camera through the PC to come on before being able to see what is behind me is not worth the $35-$40 cost of a second reverse camera. Also the reverse backup camera has reverse viewing,(you see the driver's side of the car on the driver's side of the lilliput screen) and it has distance and parking spot line references.
                          I Like the Soundman98's idea of using the 4 Channel CCTV Security 3G Mobile & iPhone View HD DVR from ebay, but like you said it's another box in the car. It would be nice to have motion sensors,( also used for parking assist) that would bring the carpc out of hybernation and automatically start recording, great if someone decided to try to take you car for a joyride, or someone hits your car why'll it is parked, great evidence to take to the police.
                            I am quite interested in this.
                            I would like to have 4 cameras on my ute one for reversing, one forwards, one underneath near my front diff and another that can go whever I feel it is best used..
                            I want these for when offroading to show when I might be about to hit something or what is going on under my car at any point in time..
                            This is where my requirements start getting tricky..
                            A) My cameras will need to be waterproof and reasonably adept at low light conditions...
                            B) They really need to be computer controlled as I want to have all 3-4 on screen but at certain points in time I need to call them up individually so I can see exatly what that rock is doing under or in front of me etc..
                            C) I would love to be able to hit a button either after something cool happened (grab the last x minutes of film from all and store) Or Before hand hit record..
                            Sorry little bit of a hijack but I thought some of my ideas might help think about requirements / best ways fo achieving different goals.. If need be I can get it split out.
                            I was thinking look for good usb cameras simply because I want so much control over the display, not just multiplexed into a single view and stored.. But I am not sure if any usb cameras are up to this task yet.. So far I haven't looked too hard for this..
                            Cheers
                              Cheers
                              You're going to want to build a housing for the stuff underneath if you go with a USB. There's nothing on the market that would stand up to those conditions without it. There are plenty of cheap, very small composite cameras that could be mounted up and out of the way that would give you a good look at your diff. I have a small 4-chan multiplexor that lets me select any camera for a fullscreen view, or puts them all into a single split screen. Think of it this way: A nice HD front webcam to record the trip...that's your geewhiz isn't that neat camera. The 3-4 small composites around/under the truck are your tools....to give you a view on those tricky offroad sections. If you want to record them, you can using a capture card attached to the multiplexor, but in normal offroad situations, that's not really what they're for.
                              Edit: the other advantage the composites have is that many come with IR LEDs for low-light conditions, which should do a REALLY nice job of lighting up the underside of the truck when you need it.
                              Cheers!
                              VegasGuy
