Joycon and Mondeo MK2 steering wheel controls
  • Joycon and Mondeo MK2 steering wheel controls
    Hi Guys my joycon arrived today, now how do i connect it? The yellow Plug for the steering wheel controls has 3 wires for it, which 2 do i use?
    Any help would be great as my gear stick gets in the way of the volume control on centrafuse
    Adz
    Ok got it connected but the joycon explorer says only one button detected?
      if the wires you found for your stock steering wheel control wires has three wire, more than likely you have 1 ground wire and two control wire. so on the joy con , one input will be ground and the other two will be the other inputs. connect it as per instructions and run joy con explorer to find which wire does what and assign them to a keyboard stroke. run centrafuse and map the keys out..
      follow the vid too.. http://www.youtube.com/watch?v=JtzPmfz6J4o
      CarPc
      Project "Driver"
      Planning [99.9%]
      Parts Collected [98.5%]
      Installation & Fabrication [98%]
      Total Completion Level [96.9 %]
      http://www.mp3car.com/vbulletin/work...ct-driver.html
        Found that one was a speed signal wire so didnt connect that, but the other 2 are ground and date, but it only shows one button, even adjusting the pot on the board doesnt show any more buttons
        Adz
          you may have to search for more wires......
          CarPc
          Project "Driver"
          Planning [99.9%]
            Because Ford Mondeo 96-00 Radio controller is not resistive, you need a Resistive Button PCB that converts it into resistive controls.
            Click image for larger version
            PDF version
            http://www.changjack.com/KN/1045/KN1...stallation.pdf
