JoyCon EX Switched Between "Current" and "Previous" Settings
  • JoyCon EX Switched Between "Current" and "Previous" Settings
    Hi, I have a JoyCon EX setup in my G35 with my CarPC and Centrafuse 4. Originally I had the JoyCon configured to control the system volume (instead of the volume shortcuts in CF). I have since changed the configuration and set the volume buttons to work with the CF volume shortcuts.
    However, the old settings are usually active, still! Then, randomly, the new settings will start working. For example, I start the car and begin driving, the old settings are in place. While driving, after some time, I hit the volume up/down key on my steering wheel and now the new settings are being used (volume indicator in CF goes up or down).
    Has anyone had this happen? It seems that JoyCon has both settings applied and it doesn't make sense!
    Thanks,
    Josh
    2003 G35; Factory Navigation; CarPC
    Progress [IIIIIIIIIIIIIIIIIII-] 90%
