Recommended usb keyboard button emulator?
  • Recommended usb keyboard button emulator?
    Hi,
    my first post on MP3Car, such a great resource
    I'm almost at the point of installing my CarPC in a 2006 Mazda 3 MPS, consisting of a mini ITX setup, Carnetix PSU and 7" touch panel. The touch panel is the most interesting as I'm housing it in a flip-up housing that previously held a "Chinese GPS" unit that proved largely useless for my needs.
    Link to unit:
    http://www.ebay.com.au/itm/190817606...84.m1423.l2649
    Under the screen there are six physical buttons I'd like to utilise under Windows. I'm happy enough to wire up a custom PCB with proper switch placement but am not sure on what sort of device I should use to emulate key presses. Would that be something like an iPac ($$) or is there a considerably cheaper option out there?
    JB
    if i remember right, there is code somewhere to use an arduino for the same purpose.
    next project? subaru brz
    carpc undecided
      This code I need please, if anyone has it available .
      Thanks in advance,
      Dave
      Vauxhall Astra SXi Car PC installed.
        i have one of these for my mame machine: http://www.ultimarc.com/ipac1.html
        no reason you cant utilise this in the car, standard cat5 cable works great for wire runs if you dont have room available in the area where the buttons are. i picked mine up from these guys http://ozstick.com.au/
        Originally posted by ClockWorK
        Remember, as soon as you make something idiot-proof, they will come out with a better idiot.
          I already have the Arduino Uno R3 and nano, and really want to utilise these for steering wheel resistive ladders, etc. If anyone has the Arduino code I would be really grateful .
          Thanks in advance,
          Dave
          Sent using Tapatalk 2
            lol i was replying to the OP as he didnt mention anything about resistive buttons.
              No Probs. I realised that but thought I ask since someone had already replied with it as a possible solution .
              Maybe I'll get lucky....
              Cheers,
              Dave
                You could always use a joycon I've got one for my steering wheel and it works very well.it can cope with about 28 physical buttons and its pretty simple to setup. http://rcjoycon.com/base_3//menu_10....m_board_idx=16
                I would also be interested in the code for the arduino if anyone has some info.
                Sent from my GT-N7000 using Tapatalk 2
                  Thanks all for the tips - I recently built up a cocktail arcade cabinet using an Ultimarc JAMMA adapter, so funny how the CarPC project uses the same sort of stuff Another utility found online remaps keyboard commands to joystick buttons - I've a few generic USB gamepads which might work (I've only about six buttons I want to make, after all):
                  http://www.emulation-evolved.net/?q=node/19
                  Will also look into joycon adapter.
