CAN BUS to C2R-VW2 (PAC Audio) to JoyCon EXD - Will this work?
  • CAN BUS to C2R-VW2 (PAC Audio) to JoyCon EXD - Will this work?
    Hi,
    I have a VW Golf GTI Mk6 2011 which uses CAN BUS for its steering wheel controls for the factory audio.
    I would like to replace the factory audio with a Nexus 7 but retain the SWC.
    I know JoyCon can do this for cars that use resistive and digital signals on the SWC, as the VW uses CAN BUS the JoyCon is not suitable.
    I was wondering is this setup would work:
    VW CAN BUS -> C2R-VW2 (PAC Audio) -> JoyCon -> Nexus 7
    Here are some references for the PAC Audio, would anyone be able to confirm that this setup would work with the JoyCon
    C2R-VW2
    http://www.pac-audio.com/productDeta...&CategoryID=26
    CarPC JoyCon EXD
    http://www.cartft.com/en/catalog/il/1738
    I think as long as the PAC Audio is converting the signal to resistive / digital, it should work with the JoyCon. Its just that I have no way of confirming this.
    Anyone?
    Id like to know this too, as im.in the same boat
      Forget the PAC Audio, get a Joycon EXC. The EXC is can directly receive the CANBUS signal.
