Logitech RF KB/mouse...
  • Logitech RF KB/mouse...
    I have a logitech RF USB mouse/KB.
    Anyone else have a problem on EPIA M's where your mouse will jump irratically around the screen when you boot up and have to disconnect it and reconnect it after you have rebooted to get it to work again correctlty? Seems like it has only happened in my XP.. also sometimes I have to loose signal on occasion.
    Anyone else experience these problems?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Do you have a serial GPS? If so, go to hardware manager and you will see a "serial mouse" that you don't have. Well, it's your GPS...do a properties on it and disable it. Reboot and the problem will be gone...
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
      nope.. all are USB
        So you've got a usb gps then? Are you using an usb/serial adapter on it?
        -Nick
        _____________________________
        Since when is insanity a bad thing?
        www.mp3vw.com
          Also most USB GPS recievers have the USB - Serial adapter built right into the unit even though all you see is the USB coming out.
            Or those that are pure usb often employ a driver that acts as a usb>serial addapter, so that any (generic) software can communicate with the gps.
            -Nick
            www.mp3vw.com
