What do you use for mic input?
  • What do you use for mic input?
    I was looking for a small microphone like the ones typically associated with professional hands-free cell phone installations, but couldn't find any on the 'net. I did find an Andrea SoundMAX (link below), which might be fantastic, but from what I read it appears to require some specialized Cadenza(?) hardware for optimal functionality. Does anyone have suggestions as to alternatives?
    Thanks,
    --Ed
    http://www.andreaelectronics.com/Buy...beam_Array.htm
    I have been exploring the microphone front lately. I have found some good canidates in lapel/tie pin microphones used for presentations and stuff. The problem with these is they tend to require a battery and I don't want to have to switch a mic on and off.
    My car has a built-in mic grille where the OEM cellphone kit goes, so I need something sort of flat to mount behind that. I was probably going to just end up tearing apart one of those standard beige boom mics that comes with every soundcard on the planet and hot-glue the element onto the back side of the grille. I suspect that it will function quite adequately for what I need!
    At least it will be cheap.. I have tons of those mics. If it doesn't work, at least I didn't ruin a $35 mic
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
      One thing you could check out would be those cheap PC Microphone with headphones setups, the mic is pretty small and is small enough to sit in front of your mouth attached to headphones, it just plugs into a normal PC Mic input as well. Wouldn't be very hard to modify the casing on one of those.
        I have done that research in the past and you guys can probably find the following entertaining:
        I have a autoPC from clarion and it came with a mic. It's pretty good and work very well. Upon further research, I found out that it's the same mic that auto cell phone installer use for hands free system (good ones). They can run you as high as 40-50 bucks for such a mic from people like Nokia and Ericsson. I found that in the past, you can walk into a alarm shop where they install hands free systems and they have an extra one lying around. I got one free. How well does it work? As well as the stock mic from AutoPC. Accuracy: 75-80% Cost: 0-100 USD
        I wanted to look at other options. I went to microcenter (try any computer shop like compusa) and get a cheap desktop mic ( the small ones that sits on top of your monitor) and I found out that if you place them close to the person in the car -- ie near the visor, they will do a great job. Cost: 5-15 bucks Accuracy : 50-75%
        I also look at the optional mic from autoPC but that mic alone costs 150 bucks and I do not work for FBI or NSA so I don't need that powerful mic. But I was told that that mic can pic up your voice while driving with the top down at 65mph easily.
        Currently, I went to a local dollar shop (dollarmart, dollar deals etc) and I found a cell phone hands free set -- the one with ear piece and a small mic on a small boom with 3/32" out connector. I got me a 3/32=>1/8 connector and a splitter. Now I can listen and talk at the same time. Even with music on, I was able to talk to my car today and got accurate responses 100% today. So the cost: 1.08 including tax. I had the connectors sitting around. Accuracy: 100% so far.
        - Lwin M. Maung
        If it's stuck, force it. If it breaks it needed replacing anyway
          I ended up chopping up a desktop mic and putting it behind the OEM grille for the cell phone mic. It works like a champ. I thought i had damaged it when I did a test recording with sound recorder, but it turns out it was just the codec or something (audio had all kinds of pops and clicks in it) -- it works fine for the voice commands I have set up, though!
          MY CAR IS FOR SALE!
            I've been considering installing a mic to use with Copilot, but I've wondered how well it would deal with my music playing. I wouldn't want the thing going off because it "heard" the music say something.
            A digital mind lost in an analog world.
            Learn to ask smart questions!
            http://www.catb.org/~esr/faqs/smart-questions.html
            My car PC: The Lost Cause!
              Seraph:
              Where do you place the mic?
              -TJ
              Smart Playlists Plugin for RoadRunner
              CarPC - 05 Acura TL Navi (pics soon)
              Retired CarPC - 03 Infiniti Qx4
                I normally run the wires all the way around and up so that they are right beside the sun visor in the center or on the door beside the head.
                - Lwin M. Maung
