Lilliput Touchscreen Alternate Driver
  • Lilliput Touchscreen Alternate Driver
    For whatever reason, I could not get the included Lilliput touchscreen software/driver to work with XP on my Compaq Evo. I tried uninstalling and reinstalling numerous times with several different errors. The I searched and found these. They don't appear to be much different, but worked the very first time for me. If you are having problems give them a try.
    Fabricator
    It seems like Lilliput monitors come with the old drivers. The new drivers from our touch screens will also work fine. These will also work with all the xenarc touch screen monitors.
    http://www.digitalww.com/downloads.htm
    Armen
      Any advantage to using the newer drivers?
      Scott
      MCS-PC
      Epia M-10000
      XP Pro; 512MB; 60GB (2.5")
      Panasonic Slot SlimDVD/CD-RW
      7" Lilliput (Touchscreen)
      Casetronic C137 w/ 90W PSU (Temp)
      19V Laptop Adapter (Temp)
        The newer drivers can handle multiple touch screens, I think. Other then that if your drivers work then you shouldn't worry.
        Armen
