Media Remote - Not Working - Can You Help ?
  • Media Remote - Not Working - Can You Help ?
    I am having a problem with mediaremote ( http://www.mediaremote.com/ ) working. The remote has fresh batteries. The software is installed and working correctly and it even worked at one piont but now it does not. The drivers have been re-installed and the receiver can be seen OK.
    Is anybody using this remote? Anybody have the same problem with it or a similar remote from X10?
    Does any one know how to test these ( tried with Media Engine No joy ) - Does any one know the exact device driver for Girder ?
    The remote is model number UR85A and the receiver is USB model number CM19A.
    My Project Site
    Very nice looking device. I'm assuming you have not yet interfaced to Girder?? Is this a clone of some other X10 remote?
    MikeH
      I am having trouble with the same remote.I could only get it to work at a range of two inches or less. The problem is the usb ports on my motherboard (Via Eden 5000) are under powered. I tried a powered usb hub which increased my range up to two feet. That still isnt good enough for me. I just bought a serial receiver,model number MR26A, off e-bay. I am hoping that will work better, as I really want to use this remote.
      Go here to get the plugin for girder http://www.girder.nl/plugins.php
      It is at the bottom of the page labeled X10/ATI remote plugin.
        Anyone get this to work with girder and is the range acceptable?
          I believe the Girder Lola plugin will work with this. I have a Lola which comes with the CM19A. Also, I get like 20' range and got maybe 5' more after replacing the tiny antenna with about a 1 meter wire (not exactly ideal for the car). I also found it can transmit and recieve X10. The MR26A doesn't work with the remote though because it doesn't send a standard X10 signal. I think it's using the same frequency, but it gets nothing at all.
            Did you try the test software that I sent you a link to (before you implemented Terran + SO v2.1)?
            C!
            http://carpc.riposte.net
            I reserve all rights in connection to each post I author, without exception.
