TV Tuner
  • TV Tuner
    Any chance I could somehow use my TV Tuner card and a mobil TV antenna to recieve and watch local tv on my pc??? If not, let me know how it would work.
    Thanks,
    Landon
    you could do that.. you won't get reception while driving though. Most tv tuners have a setting to switch for broadcast or cable.
    '98 Explorer Sport
    80% done
      Why would there be no reception while driving??
        you need a special antena that is like the size or a car's roof in order to get reception. The reason is that broadcast TV was not designed like radio. Meaning that it was not designed to be picked up while moving. I had pretty good antenas on my truck and i could pick up sound just fine but no video.. it was hardly viewable.
        '98 Explorer Sport
        80% done
          I will have to throw my 2 cents in. I had a little portable 7 ich B&W tv that i used to throw in the back of my truck before installing a multimedia system. I used to get pretty good reception on the same channels i would get normaly. didnt make a difference if i was driving or not. I have yet to hook anything up to my TV tuner card but if a little portable tv can pick it up i dont see why a tv tuner card with a good antenna couldnt.
            Thanks,
            Landon
            I got a WinTV card in mine, all I use for an antenna is a old TV antenna the kind that sits on top. I'm planing on getting a amplified mobile antenna that sticks to the inside of the rear window. As for reseption, if you live in a city you will get the local channels... the quality is actualy good in the Boston area.
              If you want to watch TV while driving, you should get this:
              http://www.detnews.com/2004/autoscon.../g03-35101.htm
              And I can you tell what is a good tv antenna for my car....where can I get one?
                Try hooking you car's radio antenna to the TV card. Worked for me.
                ODYSSEY
                Originally posted by Tidder
                Digital-Car UK|
                (\__/)
                (")_(")
                  If I do that, how is the image quality of the TV while driving. I know I won't be watching TV while driving, but the passengers might. I haven't check what type of input the car radio antenna have, can you tell me how I should hook the car's radio antenna to the TV card? What type of adapater should I get?
                    Depends on how strong the channels are. Weak channels might fade in and out while driving (55+ mph).
                    Find some cheap rabbit ears and place them in the back window, see how well of a single you get.
                    Technically, antennas are tuned to frequencies. The higher the frequency, the shorter antenna is required. TV is VHF-lo (55.25-83.25Mhz), VHF-hi (175.25-211.25Mhz) and UHF (471.25-801.25Mhz), FM (88.1-107.9Mhz) is between VHF-lo and VHF-hi.
                    http://hotspotcb.com/cbshop/techtips/ANTtool.html
                    ODYSSEY
                    Digital-Car UK|
                    (\__/)
                    (")_(")
