Input Devicefor Winamp
  • Input Devicefor Winamp
    Hi,
    I'm trying to complete project of Jukebox with PC inside working with Winamp, Standard LCD and Keyboard input.
    I'm searching for Winamp opening file according to a button switched, for example, if i want "Let it Be" i have to press 1, if i want "tutti frutti", i have to press 2, and that way for 50 Songs (means that i have to press 1 and 0 for son number ten).
    Please help me because i have no solution, or it's possible to try other playing software.
    Oliver (from France, sorry for so poor English)
    Sounds like a job for a small VB app to me...
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
      checkout and learn www.girder.nl I'm pretty sure it can handle it, right defiler?
      My cars
        Oliver.
        If I get it right, you want pushbuttons to interact with winamp.
        you can relatively easily interface 15 buttons/comport to winamp
        try this guide
        http://www.modasylum.com/guides.php?guide=21
        note: if you have hard times in english, PM me. I'm from Québec and always willing to write in french.
        -Mars
          I had a Winamp plugin which did EXACTLY what you wanted, waaay back when I had V1 of my Carputer...
          Basically, all you needed was the numpad from a keyboard, and you could control everything. Press 8/2 for volume, 7/9 for searching through the track by 5 seconds, 1/3 for skipping 10 tracks at a time, 4/6 for prev/next track, 5 for play/pause, 0 for stop, - for shuffle on/off, and then use + then type the playlist number, then + again for it to change to that song, ie +628+
          I'll see if I can dig it up...it also is used to control a HD44780 based character LCD, if i remember correctly!
          Garry
          Co-Developer of A.I.M.E.E
          www.aimee.cc
            OK, can't remember if this is actually it...but this seems to ring a bell...
            Lorty's mp3Car plugin
            Garry
            www.aimee.cc
              Damn staight!!!
              Aura MR62 (F and R)
              My Current MP3s
              IamDefiler.com
                Reply for winamp commands
                Garry
                You seems to understand what i need, but the problem is that i want to choose by entering a "code" , for example to have the fifth song i want to push 5, for the ten's one i want to press 1 and 0.
                This is for being in the same configuration as olds jukebox where you choose your song on a panel.
                I can use other software if you know one working with LCD HD...., let me know
                Thanks in advance
                Regards
                Olivier
                  From that..I reckon you're gonna either have to:
                  Find a Winamp plugin that does that (proved not so successful)
                  Write a Winamp plugin that does that
                  Write a program which can take the input from a numpad and push that to Winamp.
                  Panic!
                  Good luck!!
                  Garry
                  www.aimee.cc
                    There is a plugin for Winamp that will let you choose a track based on its position in a playlist. The downside is that you will have to have a printout of the list with you to find a song.
                    Basically, you hit the + key, type the number, then hit + again, and off it goes. I think I have it here if you're interested. I also have that plugin that drives an LCD character display and gives keypad control too.
                    The ALEXIS Project
                    Color Coding :
                      Thanks for info, i tried to find it on winamp site but i don't succeed.
                      Please give me plugins name in order to stop this boring research for pleasure.
                      Olivier
                        The LCD one with keypad control is located here:http://www.markuszehnder.ch/projects/lcdplugin/
                        The ALEXIS Project
                        Color Coding :
                          What a pain in the ***! I could imagine looking over at my girlfriend and asking, " hun, can you play some <insert band name here>?" And her going into the glove box, instead of pulling out a CDCase, she pulls out a printout of my playlist.
                            Yes, I agree it is a pain, but how else could you do song selection with only the keypad? There is another plugin that turns the keypad into like a phone's keypad, so you hit 1 multiple times, through A then B then C then 1 again, hit + to move next etc. Now THAT'S a pain in the ***!
                            Better yet, create a master playlist, set Winamp to shuffle, and let it roll. Nuff said.
                            The ALEXIS Project
                            Color Coding :
                              That's the one I was using, and described above
                              That was an awesome little plugin, everything being controlled by just a numpad
                              Garry
                              www.aimee.cc
