Xbox volume control knob
  • Xbox volume control knob
    Does any one know a way to control the volume on a xbox which would be used for as a carputer and a console. It would have to have optical output capabilities.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    not to flame, but seriously
    goto an xbox forum
      Tried searching the xbox forum but was unable to find anything. I asked here because I would be using it as a computer and a console in my car and thought someone might know.
      This is the amp I was thinking of using:
      http://www.sonicelectronix.com/viewitem.php?id=1699
      Installed
        Quattro, what OS are you using in the Xbox? I believe if you go w/ Gentoox you can just use the Xbox controller. Not 100% though. However, if you plan on using XBMC or XBMP, I don't think there is any external way of varying the volume w/o using the headunit. However, that amp looks to have volume control built in, so that may be the way to go...I hope I helped a bit.
        "I'm a dick!"
        "I must seek knowledge and it's bastard son truth" - The State
          Do you mean an optical input to the controll you are looking for or do you mean what you said optical output
          the Audiobahn ADD51T is a 5.1 processor for cars it has spdif and optical in it is the only 5.1 unit for cars that has a volume controll and does not require a analog rca signal to controll volume you can't have digital and analog at the same time with 1 sound card so this unit is the only way to go
            I have an EQ setup inbetween my xbox and the amps to control the volume. check it in my sig (Blazer)
            -NizZ8
            ! Xbox Blazer !
            . NizZ8.com .
              http://www.mp3car.com/vbulletin/show...e+control+knob
              StreetDeck.com Developer (I am Chuck)
              Get StreetDeck at http://www.streetdeck.com
              The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
