creative and girder
  • creative and girder
    im a newb. trying to learn out to use girder. im lost. i dont know where to start. i just got the creative pc-dvd credit card remote. i would like to set it up so i can use it with mediacar. any help would be great.
    • DS700YYV
    • Opus 150
    • XP Pro
    • Nehemia 10000
    • Indash Housing
    Setup the remote so it installs necessary drivers, get rid of all extra software. Setup girder with creative device (get plugin at girder.nl). Get Coyotes sample girderfile. Load it, play around with it. Let girder 'learn' your different keys.
    If you are still lost, check the help section on girder.nl for basics, it got me started.
    Michael
    "It does not understand, if it does not ride."
    M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
    RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
      how do i load what coyote has created? and i cant seem to get girder to see the remote. the software that came with it sees it but girder does nothing. cant seem to find that plugin u talk about either. sorry if im just blind.
      • DS700YYV
      • Opus 150
      • XP Pro
      • Nehemia 10000
      • Indash Housing
        got girder to see the remote. but how do i load what coyote created.
        • DS700YYV
        • Opus 150
        • XP Pro
        • Nehemia 10000
        • Indash Housing
          Check here for creative remote plugin.
          Install it in girder plugin dir. Open girder-settings-plugins,
          look for window on the right, scroll down, there you must enable the plugin.
          Also auto-enable plugin device for next startup.
          if you press a key on your remote the little light on the right hand bottom
          corner in girder should flash green.
          To install Coyotes girder file, just 'open file' it in girder
          and then make girder 'learn' your Creative keypresses (learn button).
          Be sure to save after you learned your keypresses.
          Michael
            do i highlight and copy coyotes girder file then save it. if so i have tried that. says invalid.
            • DS700YYV
            • Opus 150
            • XP Pro
            • Nehemia 10000
            • Indash Housing
              actually is says cannot load data file.
              • DS700YYV
              • Opus 150
              • XP Pro
              • Nehemia 10000
              • Indash Housing
                Make sure the file ends with .GML
                I think if you copy and/or save it, XP auto-renames it to .xml due the file characteristics which are or resemble a xml file.
                Michael
                  i have tried to save it to .gml and it gives me the same error.
                  • DS700YYV
                  • Opus 150
                  • XP Pro
                  • Nehemia 10000
                  • Indash Housing
                    So it was changed to .xml?
                    Try to load it with 'import group'?
                    what version of girder you use?
                    I guess I'm out of idea's.
                    Maybe address Coyote with this problem in the Mediacar section?
                    Michael
                      no i saved it as .gml since girder looks for that. i have the lastest version of girder 3.3
                      • DS700YYV
                      • Opus 150
                      • XP Pro
                      • Nehemia 10000
                      • Indash Housing
                        i appreciate all of ur time. maybe one day ill figure it out. or maybe someone can show me how.
                        • DS700YYV
                        • Opus 150
                        • XP Pro
                        • Nehemia 10000
                        • Indash Housing
                          Try to load another .gml file from girder.nl,
                          just to narrow down the problem.
                          if it gives the same error, it's not in the Coyote file,
                          if not, try a fresh download of Coyotes .gml file.
                          I'm using girder 3.2, but I can't believe they wouldn't
                          make it backward compatible.
                          Michael
                            Get up on your feet, soldier!
                            I struggled with it for two days,
                            but I can tell you it has been worth it.
                            There are 2 1000+ posters on this board
                            who use this setup, I think.
                            Defiler and CCSNet. Maybe pm/address one of them in the Mediacar section?
                            Also see the girder forum, home of the real geeks.
                            Michael
                              A little OT here but same device...
                              Is it possible to get a serial-to-usb converter and get the Creative remote to work? I couldn't find any USB IR receiver anywhere cheap. And I already use my Xenarc Serial TS on the serial port. Can I use a serial-to-USB for the touchscreen then if not the remote???
