Has anyone hooked a webcam to their carputer? I searched but
  • Has anyone hooked a webcam to their carputer? I searched but
    could only find references to rear view ideas. I want to have a webcam on the dash for when I track the car, etc...
    What would be a good camera for this? 30max fps decent enough for a video of a drive? Do the USB camera's work ok?
    cheers
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    I am in the process of connecting two webcams to my carputer. I plan to use them for video/audio security. They are the logitech quick cams. I have tested them with a epia m10000 with a 20gig hd. Having both recording video and audio at the same time to two different partitions on the hard drive, I am able to get 22 fps from each camera.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
      Considering that NTSC movies are 29.97fps... yeah, 30 is enough.
      The question is, what software to use?
        how about while playing mp3's?
          this is kind of similar but not.....is there a way to hook up 3-4 cams and record/snapshot all of them (these cams might be video tho not usb)
          Vehicle: 2003 Mistubishi Evolution
          PC Specs: 1gHz Nehemiah M10000
          512mb RAM
          Windows XP Professional
          80gb 7200rpm 8mb cache HDD
          UI: MediaEngine 2.1
            There's PCI cards that let you do just that. They're used usually for CC security cameras.
              I too am using a cam for security. But it's on a servo, that turns towards motion. It's set to record 30 sec. of video towards the motion if there is any type of vibration through the car. The only problem I have with this system is that you can't let your car sit for more than 2 days because it will KILL the battery.
              Mg
              Just your friendly neighborhood computer specialist.
              2002 Pontiac Trans Am WS.6
              Silver/Black
              Looks like new... Wanna know why they call me "Crash"?
                I have seen a couple of threads on live video in the car from a camera / webcam
                This one mentions it:
                http://www.mp3car.com/vbulletin/showthread.php?t=19779
                Trust USB Webcam, Facing forward (Mounted on Rear Parcel Shelf)
                Yes it is rear facing but a similar set up could be used to face forward.
                Or this thread:
                http://www.mp3car.com/vbulletin/show...era+video+race
                Or a third thread:
                I did not read the whole thing but the topic is the same, Camera in race car for video capture.
                Maybe that will be helpfull enough so I don't get slamed for saying:
                Did you really "Search!"
                Good luck with the project.
                TruckinMP3
                Read the FAQ!
                  the security system i am installing is separate from the carputer. Yes "TWO" computers in my car.
                  main multimedia system computer #1
                  abit kg7raid mobo with 1gig memory
                  maxtor 120gig
                  usb dvd+rw in the dash with xenarc
                  usb gps
                  netgear wifi
                  powered by inverter 350w
                  security system setup, computer #2
                  epia m10000
                  maxtor 20gig hd
                  2 logitech usb cams
                  power supply pw-70
                  powered by radio shack #273-1827
                  tested with winxp pro using virtualdub to capture video from both cams at the same time. both cams were recording video and audio at 22fps each had a 4gig partition and can record from each cam for about a week.
                  I am still testing this setup and it is not installed yet. As soon as I am done, I will post.
                  Memory:1G
                  Drives:160gig
                  WI-FI:Cingular
                  GPS:IG2k9
                    maxtor 120gig
                    usb gps
                    netgear wifi
                    epia m10000
                    maxtor 20gig hd
                    2 logitech usb cams
                    power supply pw-70
                    all i have to say is that sounds absolutly sweeeeeet
                    2 questions -
                    1.can u view that video from another computer (via the internet, or a wlan or something)
                    2. when you say you can record from each cam for ~a week, is that to just to one 4 gig partition? (including two video/audio captures ...from each webcam)
                    AT mobo
                    Intel Pentium MMX 233mhz
                    ESS Solo PCI soundcard
                    Linksys NIC
                    Irman
                      How do you cool them? Any special cooling?
                        partition the hard drive to three partitions.
                        I have each cam recording to its own partition, each is 4gig.
                        I plan to have it separate from the main system.
                        Also, to help eliminate battery problems I am installing a second battery and a capacitor.
                        the "security system" will be connected to the capacitor so it will survive cranking.
                        cooling? what the cams? i got them mounted on top of the dash
                        Memory:1G
                        Drives:160gig
                        WI-FI:Cingular
                        GPS:IG2k9
                          maxtor 120gig
                          usb gps
                          netgear wifi
                          epia m10000
                          maxtor 20gig hd
                          2 logitech usb cams
                          power supply pw-70
                          Didn't see if you ever mentioned what kind of car you will be mounting, but I think it would be safe to toss out a warning about potential overdraw on your power system. One carPC is enough to knock some cars right out of commission, but two of them is almost a surefire way to get some problems you might not have foreseen, especially using an inverter. If you need to use two systems I would recommend using direct DC-DC power supplies for both, to maximize efficency and minimize power draw.
                          That would be my two cents' worth, and just think: you were here to see them fall!
                          The ALEXIS Project
                          MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
                          Color Coding :
                          DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
                            I did
                            I did. It is pretty fun:
                            http://ehampshire.com/computer/car/video/car1.mpg (download before playing)
                            I used to have more videos before the HD crashed. Some good ones and night and driving through the desert.
                            --Tom
                            ME-6000, Lilliput 7" vga + touch, generic GPS, RedHat 9, custom mapping software.
                              --Tom
                              that is pretty cool... any more info about ur OS, software used to capture, what web cam you used... pics of setup, etc.???
                              i tried to go to your website but it asked for a un and pw...
                              i see u have some info here -http://ehampshire.com/computer/car/
                              correct? what OS u got and gps software
                              AT mobo
                              Linksys NIC
                              Irman
