100% Custom Keyboard!
  • 100% Custom Keyboard!
    Alright all check this idea out.
    Thoughts:
    When a key is press a circuit is completed giving you the desired keypress.
    Plan:
    Wire two wires to a button in a remote location in the car. I could pick and choose which keys I want and where I want them. I could use calculator keys / endless possibilities on that lol... I could use leds to light the keys or solar glue keys(kind that some shirts/remotes have)
    Sketch
    the keys on the left are numeric keys and the one next to it is ENTER
    Then that middle button thing is a nipple mouse I got for 10$ at MICI.COM
    that is a example of a keyboard i could HI-JACK since its clear.. easy to do
    So what do you all think, yup this is your time to bash my idea go for it!
    2005 Ford Mustang GT <- - - UPDATED PICTURES
    2003 KAWASAKI Z1000 - CUSTOM MODZ
    MBK (AIM = IllMBKllI)
    Just to give you more ideas, I found this website: http://www.keyalt.com/ In keyboards they have labels, and in the mice they have some really freaky stuff.
      To avoid destroying a keyboard you can use this solution:
      XKeys Matrix Board
      It's a USB/PS2 controller for matrix keyboard (you can also use custom "matrix" setup). It's absolutely programmable and can emulate both keyboards and mouse. Worth a look...
      Installation: 90% complete - fiberglassing
      EPIA M10000 - 512Mb - 20GB
      Lilliput 7" TS - Opus 150W PCB - DLink USB Radio - slim CD-ROM - SoundBlaster MP3+ - not so crappy 40x4 Amp - BU303 GPS (waiting for) - BT support
        XKeys Matrix Board
        A keyboard is a lot cheaper to mess with than $60!
        The problem you're going to run into w/ hacking apart a keyboard is that the switches are capacitive. Most pushbutton switches you get at radioshack and mouser/digikey are contact switches and won't work with keyboards.
        My suggestion would be to hack apart a gravis gamepad. They can be had at Best Buy for $10, they're USB, and they come with software that's programable.
        '99 Jeep XJ - 4" Lift/35's - 15"/Shuttle
          a push button should work.. It just completes the circuit for a m-sec .. That 60 dollar thing is cool also but hmm the gravis gave me new light just fight a crap controller and go.. cheap
          I found that keyboard above for 10 bucks NEW also btw
            just use the simple serial port button thingy
            one serial port can have 15 buttons (your idea uses less then that) and useing a 2nd serial port you can get 15 more buttons.. all you need is to run his lil app http://diba.hotbox.ru/comctrl/pictures.html interfaces with winamp and windows ANY key you want.. also HOLD and TAP can be difrent actions / keys
            Pete Kastner www.KastNERD.com
              Same as beaverpants, but you can use girder to interface ANYTHING with it.
              http://www.girder.nl
              guide:
              http://www.modasylum.com/guides.php?guide=21
              -Mars
                would i be able to hook one of those up in addition to my keyboard being hooked up
                  Nice one, this would be perfect for what i want to do. I have a peugeot 306 and am planning on making 5 buttons on either side of the screen (the dash is a funny shape and will have some space around the screen) to control things to relieve the touchscreen a bit and provide me with some direct access to featues that may not be on the screen at the time (reduce distractions while driving). i am planning on having volume, track, menu and play/pause on the passenger side (keep their grubby fingers off my screen) and things like direct to GPS, phone and rear view camera and the on-off on the driver side. I also have a 4 way joystick on my steering column (dunno how this is switched yet) that i want to use for track and volume and have been wondering how best to do it- hopefully this will be the answer!
                  Cheers!
                  Andy
                    Don't know if this will help or not, but I used a keyboard encoder when I built my Mame cabinet. Let me assign keycombinations to buttons. This is the least expensive one I found:
                    http://www.groovygamegear.com/Page2.html
                    Don't know if this will help or not.
                    '03 Sierra Denali
                      mbkowns, do my eyes decieve me or is that an RX8? I've been thinking a lot about where I would put a car computer in one (specifically screen), and there just doesn't seem like any good place the way the dash is setup, unless you get the trim for the GPS addon without the GPS addon, and stuff in a lilliput or something.
                      Responding to your actual question, as i think somebody else said, a cheap game pad from best buy will use easily hacked pushbuttons. Go for it!
                      Rob
                      car computer rev 5: 8" lilliput and usual suspects
                        yes thay use serial not ps2.. i guess it would be possible to conect to a ps2 but most use serial port
                          I was going to stick it in the trunk I am not building a weak PC etheir I went with a Micro ATX board and 2ghz celeron. The screen on the rx8 is RGBS so the stock navigation will be fine.
                            are you going to have a computer display?
