Xenarc mouse cursor positioning bug?
  • Xenarc mouse cursor positioning bug?
    I have a Xenarc 700TS on an Epia M10000Neh. When using a mouse (I've tried several) and hover over "some" items on application dialog boxes, the visible cursor jumps down from .25" to 1.5" below the actual point of focus for the mouse. This only happens at some places on some dialogs, usually whenever the cursor changes to a pointy hand or a two-sided-horizontal arrow, but not always. If I change monitors, no problems. If I control the pc with VNC, no problems. Only when I use the local mouse on the Xenarc. I called Xenarc and the tech said he'd never heard of anything like that. I installed the latest bios and vga drivers but it didn't help (also I still can't get 16:9 display in Win2k). Anybody have Xenarc/Epia and have you seen this problem?
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
    Nope, my USB Logitech mouse works fine with the Xenarc connected. I can use both fine... Which Touchkit software are you using? The stuff from the CD? Or one of the newer ones?
    89 Celica, CarPC installed, 1st bday :)
    http://www.fishy.net.nz/carpc/
    • MediaEngine
    • Epia V8000
    • 80GB WD 7200RPM HD
    • Xenarc 700TS
    • SB Live
    • Opus 90W
    • CIMR100 remote
    • Deluo serial GPS
    • D-Link USB radio wired to power antenna
      I downloaded the latest touchkit (3.2.0.2731) from the Xantech website but it didn't help either.
