Modifying Sony Erricson Chatboard for Car PC
  • Modifying Sony Erricson Chatboard for Car PC
    Hi guys
    anyone has experience hacking one of these beast
    http://www.ebay.com.sg/viItem?ItemId=5722131843
    to interface with car PC?
    kao
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    found 1 link.
    anyone else?
    can the origial signal be pipe in via USB?
    kao
      Yep!!!
      I have done it. Currently in CAR I had to teach all the keycodes with GIRDER and also the initializion. But post here if you want more info. Now i'm in a rush gotta go bye.
        did u pipe it through serial and use serial plugin from girder?
        I am not keen to go down the PS2 way according to the link.
        please enlighten
        thanks
        kao
          I have one of those.. got it for my old cellphone.... saw it laying there the other day
          and wondered if it would be compatible in any form....
          That would be awesome if there was some way to convert it to ps2 or serial or so...
          I have no insight to offer.. but I'll be listening to what you find
          CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
          Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
          Display: Lilliput 7" TouchScreen
          CarPuter Install
            my EPIA TC fried.
            now switching to a microATX board. setting up now. will have to wait a short while before starting work on the chatboard.
            how's your own project?
            kao
              Yes I used Serial interface and you guessed right Girder and Serial plugin. The initializion sequence is done also with girder. Here is a good link alltough I used a MAX232 IC the pinout was a little different but I still managed to stuff it inside the chatboard (there is only the cable coming out) https://securehost34.hrwebservices.n...sonChatBoardPC
              I'll post the serial config file and some key config file for girder later on. Iīts not totally complete yet but have been enough for me. It's the bomb when using GPS you can actually write the place where you wanna go. Later...
                that's cool man
                hmm.. thinking of taking one step up... convert to USB directly.
                KAO
                  Think this might come in handy.
                  http://www.compsys1.com/html/usb_rs232.html
                    Someone needs to write a how-to on this for us less technically inclined. I Need this sucker to work with my computer - thanks!
                      That usb thingy would be quite nice. How much does it cost?
                        You'd better put a pear of my serial BlueTooth chip with it, that would be
                        FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFF
                        HERE it is
                        http://www.tompda.com/bbs/display.as...orumID=1357612
                          pic of it
                          very tiny and power save...
                          that was designed for my BTGPS years ago...........
                            Hereīs some files for ya!
                            Sorry for the picture quality samsung just doesn't have it . But anyway if you look at the rear picture you can see how I planted the MAX232 chip inside. The INI file is used to configure the serial plugin of GIRDER to suit the Chatboard and the GML file contains most of the keycodes. I also added the OSD wich asks to press the SMS button of the Chatboard(needed for initializion). Just take the .TXT extensions of the files first.
                              Any help??? Donīt let the post die
