USB IR Reciever Hybernation problem.
  • USB IR Reciever Hybernation problem.
    Is there any way that i can get my USB IR reciever to reinitialize after a hybernation. It stops working after recovering from hybernation. I must unplug and replug it in for it to start working again.
    There must be some software utility that will do this for you
    Any help here guys?
    help
      I have same problem with $90 Leadtek Smart Antenna GPS 9532
        If you want USB device to work after come back from hibernation, do not share the USB device in the same hub as USB WiFi. That is how I figure out.
        I have TS, Mouse, GPS in the same 4 ports hub and all come back fine from hibernate. If I move any of them (GPS) to the hub I have the WiFi, it doesn't work after hibernate. I have to unplug then replug for it to work.
        Y2K Accord Dell GX150
        EmoRebellion is a SCAMMER
          Hmmm
          Technically it is not in a hub, it is plugged in to the extra USB/Firewire Ports from the pinnouts on my Via, Let me try to change it to the USB ports directly on the motherboard.
            Any one figure this out? I have to unplug / plug back in my usb wifi if I want to use it after hibernating..
            Current Vehicle: 2007 Dodge Nitro
            Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
            First Vehicle: 2003 Ford Ranger
              Same here
                do a search for Devcon
