TouchScreen Kits
  • TouchScreen Kits
    Hi guys,
    I`v been searching around for a touchscreen kit for my Sony XAV-7W motorised screen.
    The only place I`v been able to find a good kit from is here http://www.digitalww.com/7TSK.htm
    Any one got any recommendations? I dont want to change the screen I`v got at the moment.
    I`v tried 3m but couldn`t find any prices.
    Try www.earthlcd.com
    System status: in progress
      did you ever make the Sony XAV-7w a touch screen? if so how is that working for you now?
        Originally posted by SlashEMc2k
        Hi guys,
        Are there any drawbacks from using something like this? This looks awesome, costs 150 less than the Lilliput, and seems to have everything you would need... I imagine you would have to buy a VGA controller card for it?
        NM, I'm dumb, this is just the touch screen portion, NOT the lcd+touch screen, correct?
          Works like a charm
          Its been a while from the last post here but I wanted to let you know.
          I have installed a few of these with the last one just inchs from me now working in a sunvisor about two weeks from being installed.
          The wire from the screen to the controller is a bit on the long side (not being modded) but I was ale to make everything fit.
            that is cool I might have to get a kit for my sony XAV-7W that I picked up a couple of months ago. what kit would you recommend?
              The only one I have used is the generic kit being that I use whatever 7" LCD my clients bring me.
              http://digitalww.com/7TSK.htm
              I have had one kit (screen) go bad, from what I can tell it was due to heat (florida) but we replaced it with no problems again.
                Thanks for the info! you said you added this to a sony XAV-7w if I read one of your posts right, was it hard? How did it look and function when it was done. did it cause any issues with the motorized display?
                  try emailing motorcity he has antiglares and direct replacements and all sorts of stuff.
