Power Mate Volume Control Install!
  • Power Mate Volume Control Install!
    Now this is probably the best thing I've ever done to a car! It's a Griffen PowerMate which is basically just a nice big volume knob off a stereo only this one is USB. Turn for volume, push to mute/unmute. It's right where I can reach it with my right hand. So simple! I love it! The only bad this is the darn things costs $50!!!
    Larger Version (1,059 KB)
    Larger Version (1,108 KB)
    did you know that if you search for powermate at this very moment, it returns 308 results?
    Stealth OEM spyder
    1204 dot net!
      Maybe he is showing off his install. Ya, he should have done it in the show off your project forum, but give him the benefit of the doubt, He is not a BRAND NEW NOOB.
      Michael
        Well, it's not really showing off my ride, it's more showing off my control device. But I figure if I post to the wrong area, moderators will move it for me.
        As for it being posted a million times, this makes 1 million and 1. It's not like it's a bad thing.
          Now you need to fabricate a recess in your center console for it. That's what I'm working on, in almost the exact spot you have yours, so it will sit with the botton 1/3 recessed below the surface. Then it will stay where it's supposed to when on the road, the wire will be hidden, and it will look more integrated.
          In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
            Ive got a powermate and I love it. Are you running it through a USB hub? many people around here have reported problems with powermates and hubs
            Is this where the witty comment goes?
            97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
              I'm running mine off a powered USB Hub. The hub I have runs off 5v so I ran 5v power from the computer to the hub along with the usb wire.
                my powermate is run through a non powered usb hub, no problems here
                Signature: [==||========] 20% complete
                  "Power is being supplied by an Optima Yellow Top Deep Cycle Battery which is connected to the car's main power by an 80Amp relay which engages when the car is on and disconnects when the car is off. This allows my carpc to run off the second battery while the car is turned off!"
                  ..from your site.
                  this is excelent solution! i will do the same thing!
                  and now one question
                  There arent problem when your using both powersuplies when car is off? enought power?
                    Amazon has it for 36.99 with Free Shipping right! Sounds like a pretty good buy to me....
                    Powermate @ Amazon
                    Status: 40%
                    Car: 2006 Scion tC (Buying)
                    CPU: AOpen Pandora/1.5 Cel M/1GB DDR2/Ipod Vid
                    Screen: Lilliput 7"
                    Power: Carnetix 1900
                    GPS: Deluo GPS
                    Software: nLiteXP, RR, IG, PhoCo
                    XM: XM Direct
                    http://www.chrispuckett.com/mp3car/
                      nope, it runs perfect and stays up for hours even after the car is off. I love the set up!
