How to calibrate in 800X600
  • How to calibrate in 800X600
    How do people calibrate in 800X600 resolution since the bottom 120 pixels get cut off?
    Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
    Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
    Holux G210
    03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
    change refresh rate to 75hz.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Originally posted by bgoodman
    We're an international forum, post in whatever langauge you like.
      I'm sorry, let rephrase my question. How to calibrate the touchscreen in 800X600 mode when the bottom part get cut off?? thx
      Holux G210
        ashbosh, you can't. I tried that before. Asked several Xenarc tech support guys, too. There's nothing you can do.
        iGMon - Integration between iGuidance and Road Runner
        CFX - Skin for Road Runner
          Did you try the 75hz refresch rate...???
          I run 800x600 75hz in my xenarc and the lower part shows just fine.
          Nissan Aux-in MOD
            I did it and it worked... THNAKS A LOT. Amazing or should I say weird??? It reduces the display height, for higher refresh rates, do you know why?? I like to know.
            Holux G210
              Mine runs in 800x600 at 75hz too. I assume the lower refresh rates just don't get locked onto properly for it to resize the display to the correct aspect ratio...
              Old setup
              Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
              New setup
              Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
              Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
                Thanks all for the help, especially thanatos106. Otherwise I was going to buy a new video card and agp riser card and run powerstrip and all. Saved me some $$, time(=$$) and headache and wife beating me up for spending too much time on it. :-|)
                Holux G210
                  In the Touch config program you set the screen as a "split screen", and you tell the ts just to work with the upper shown 800x480 pixels.
                  My carputer
                  Old one
