BMW owners...i need IBUS HELP
  • BMW owners...i need IBUS HELP
    hey guys...i was wondering if anyone is using a lcd that is not indash and therefore they still have there stock cd players...i was wondering because i use an aux adaptor in my trunk that connects to the cd changer cords and has a n ibus cord that goes into it..allowing me to hit the cd button on my cd player showing 6-01 which is my aux adaptor. I was wondering if there is a way to use this i bus controller and aux adaptor at the same time so i can switch my music up and down......there is another i bus cord in the trunk i believe..its next to the car phone cables which are wrapped in a piece of felt in the trunk..there is also an i bus cord...could i use this cord then?...please let me know
    thanks
    Jason
    I don't understand - you want to listen to your pc via the aux adapter in the trunk, and also use ibus to make steering wheel buttons to change tracks? You can do this as long as you don't have a cd changer. The aux adapter (to my knowledge) has nothing to do with the ibus, so if you've already got the sound coming from your laptop going through the aux adapter for your hu, you can just buy one of the ibus controller boards and hook it up no problem.
    My install log
    My "selling entire system" thread
      alright but the only thing is my aux adaptor plugs into the ibus controller....can i just unplug that then?...i thought if i did it would not show up on my headunit
        The audio part of the aux adapter should'nt be running through the ibus plug - it should have some other plug for that. The ibus plug should be for control only - sending/receiving commands like next track, etc. However, I don't have/use an aux adapter so I'll defer to someone else who knows more than I do.
        My install log
          There are many projects like this. Car2PC-BMW is one of them which is dedicated for car pc in BMW. It allows you to control the media on your PC.
          Car pc integration with ease
          Car mediacenter
            I am using aux function of car2pc without the usb ibus adaptor
            Sound works fine but i have another ibus adaptor ( www.reslers.de ) installed in my trunk where my cd-changer used to be. Does car2pc cut ibus signals for cdchanger socket? My ibus doesn't work.
            I have ibuscomm in start-up with edited .ini file but it doesn't send/receive any signal thru ibus. what do you guys think.
            ibus error
            GTA skin
              IBus is an open bus. You cannot cut anyone's signals. So I would recommend checking connections first...
              Car mediacenter
                There is nothing to check
                one time ibus one time 12v one time gnd and one time usb
                ( www.reslers.de )
                any helpful suggestion?
                ibus error
                GTA skin
                  ok so i i tried installing the ibus today and i discconected the ibus from my aux adaptor..and as soon as i do that my cd player reads disabeled...wont play any music or anything from my comp..so i am assuming i cannot use this aux adaptor..anyone know??
                    Which aux adaptor is that?
                    ibus error
                    GTA skin
                      its the USA SPEC Auxiliary Interface sold at crutchfield... http://www.crutchfield.com/S-doxInK3...tor&i=581DFBMW
                      i have to plug in the i bus to it or it says disabeled on the screen..or nothing at all
