USB Microphone?
  • USB Microphone?
    i'm trying to find a usb microphone so i haven't gotta rip my car apart to start using a normal mic to do hands free
    any ideas?
    can't be too expensive (or too big)
    My install... check it out!
    www.mp3car.com/vbulletin/showthread.php?t=56599
    Check out the logitech USB microphone. My grandparents recently got one and it sounds great.
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      cheers i'll have a look
        you reckon it would be easy to tear apart and mount in the car somewhere?
        obviously its a little big for in car use as it is
          Well, you would need to hide the base of it somewere (the analog -> digital converter sits there). Otherwise the microphone element is small. Just extend wires to it and you should be done.
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
            ok, thats cool, i can put the base behind my dash where all the cables and my usb hub is.
            however i'm investigating a cheaper alternative. apparently the 3.5mm to usb converter for the playsation singstar games works and i'm bidding on ebay for one at about £5
              Is this for their bedroom webcam?
                lol
                  No. For google talk.
                  GammaControl v2.4
                  SKINbedder v3
                  1995 Lexus SC300
                    i have bought a PS2 Singstar mic to usb adapter
                    and when you plug it in it recognises it as a usb audio device, next step is to plug in a normal mic and see what happens
                      well it didn't work
                        Greenbeast i just tried what you were thinking about the usb mic for the singstar and the logitech mic for ddr max will work with a pc. i can post a screen shot the problem you are running into is that the singstar usb converter plug is mono and it is slim where the tip is. Its made like that on purpose by sony. uhm a typical stereo plug is fatter where as the sony mics for singstar are a standard size plug but the encasing or plastic on the wire is real slim and rounded so as to fit more in the plug socket than a conventional plug. So when i plug the singstar mics in i do in fact have a signal on the pc. there plastic housing is very slim
                        KIAs can have car pcs too..
                          This is another way i did it take the usb converter apart and plug ya mic in. 3 screws to the outer casing underside. 2 screws under the rubber and 1 screw underneath the sticker. 4 screws holding the circuit board in. it works for me that way. because then the plastic circles on the outside of the interface do not interfere with the diameter of the plastic housing on a standard mic plug.Selling trick by sony to get us to buy there mic. I know that it works. I opened up speech and was training my pc for 5 minutes just to test it out. It should have create a volume control that says wave in.
                            My sig needs updating going thru reinstall of carpc software added blue tooth but deleted bluetooth radio when doin nlite(I am a idiot )
                              cheers for that. i did consider taking it apart, guess i might as well as its worth jack **** to me at the mo
