girder and phidget circular touch sensor
  • girder and phidget circular touch sensor
    since i dont know the first thing about coding, could i use a phidget circular touch sensor:
    http://www.phidgetsusa.com/cat/viewp...=4100&SKU=1016
    and interface with it using girder?
    Thanks,
    scott
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    I am talking with one of the tech guys at phidgetsusa right now about this. There may be a way to do this without having to use girder (functions would map directly to key strokes). I'll post when I hear more.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
      cool! looks like i'll have to hold off on gettng my panel retextured...again :-(
      M10k
      My Car Pc Install
      My Boat Pc worklog
        Well, the folks at PhidgetsUSA are confident that it can work. It just needs a little programming to work with whatever frontend we are using. I'm going to buy a circular and maybe a linear if I decide I like that too and get to learning how to program it. I'm a mech-e so this programming stuff is all new to me.
        I plan on more than volume control for it though so stay tuned.
        One thing I like about the linear is that you can program it so that different sections are "soft" buttons. I think the max is 8. But, that means that you can switch buttons based on whatever feature you were using at the time. I think the circular can be programmed in this way, but it could be hard to determine which one is which if you are trying to hit each octant as a separate button.
          Still working on this, I haven't forgot about it. Just coming along slow since I don't know any programming (and the devices are backordered).
