pda for datalogging & mp3 files?
  • pda for datalogging & mp3 files?
    i just found out & joined this site after being referred here from a fellow member on a car site. interesting stuff.
    i have 90 eclipse & a pda which i use for a datalogger. i have the mmcd software loaded in the pda (palm iiix) & i love it. recently though i have been rethinking my whole stereo & electronics setup. i was thinking of gettting rid of my multidisc cd-changer & getting a stereo receiver that plays mp3 files or an ipod music file via an external input. then i got to thinking why not swap out my pda too with one that can do both datalogging & play mp3 files? my goal is to have a pda with mmcd datalogger loaded on it that i could also plug into my (car) stereo receiver to listen to the stored mp3 files. is this do-able??
    i have researched pricegrabber (& similar sites) for pda's which also handle mp3 files. the list i saw from those searches did not match this list of pdas which can operate the datalogging software: http://mmcdlogger.sourceforge.net/#Palm%20Support
    so it appears the two can not coexist on one PDA, but i want to believe there does exist at least ONE pda that can host mmcd & mp3 files. is there a more recent, updated list? or does anyone know what i must do to make this work?? please help.
    does ANYone know about datalogging & mp3 playing capability with a pda??
      Are you limited to using a Palm PDA? I have an iPaq (windows mobile) but most relatively recent PDAs (palm, windows, etc...) support playback of mp3 files.
      What pda do you have now? The only thing is song capacity will be limited by what type/size of card media storage you can use.
      Nick
      '99 Ford Escort ZX2 CarPC <-- RIP Feb '07
      2006 Chevy Equinox LS (Current Project)
      **VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
        i currently have a palm iiix. it has no mp3 capability. my hope would be to get a newer palm in the hope that i can still use some of my accessoreis, but it does not have to be one.
        my intent is to have a pda that can play as many or more songs as a 10-disc cd changer hence replacing its function. i don't know for what a comparable capacity would be, but assuming a typical cd will hold anywhere from 8 to maybe 15 songs per disk, that could result in ~150 songs. i figure if i have a pda that can store/play at least that many or close to, then i'm good to go.
        the only catch is, it has to be able to run dataloggin software. i use mmcd.
        http://sourceforge.net/project/showf...roup_id=114453
        forgive my inexperience in all of this, but it only recently dawned on my to rethink my audio setup so i am not at all familiar with ipods, ipaqs, nor mp3 capable pda's. so do you know of any that have both of these capabilities or have you ever used your pda as a datalogger?
          is what i'm looking for non existent?? aren't there pda's which also store mp3 files and can house datalogging software???
            Does the datalogging software you want to use have a forum? Perhaps checking there to see which newer Palm models can work with it would be better than checking here.
            Also, you may want to try to find a different datalogging software. "data logging Windows CE" yeilded alot of search results on Google, and nearly all Windows CE/Windows Mobile PDAs can play MP3s and videos. I'm not very familiar with data logging, so you'll have to search through and find what you need.
              [QUOTE=tom61]Does the datalogging software you want to use have a forum? Perhaps checking there to see which newer Palm models can work with it would be better than checking here.
              ...{/QUOTE]
              lol! actually there is forum for the datalogging software & someone on there specifically suggested that i come to THIS site! go figure.
              i prefer to use the mmcd software because i'm familiar with it, its freeware & it works well with my car.
              but, that is only half of the concern. i also want to know if there are pda's that have mp3 capability that can connect to a car stereo receiver and function similar to a multi disk changer. it seems there are car receivers that have aux inputs or external RCA connectors for this type of purpose, but i'm not sure how they work. will the receiver display info & offer control of the mpa player (or PDA) sort of like how it does with cd changer controls? or is the control done strictly from the pda & the receiver has no controller function & displays no info about the mp3 file being played?
              anyone familiar with that?
                I mentioned above that pretty much any PDA you buy now will support playback of mp3 files. The early palms may not, but just about all the ones you can get now either have a builtin media player or you can install any number of 3rd party ones. I think you need to check and see if you can find a newer palm model that runs that datalog software, and then go to Palm's website or do a google on the model and see if it supports playback of mp3.
                It'll be a pretty basic setup, the audio output (headphone jack) of the PDA will just plug into the AUX input of your head unit like you said. You'll have to control the music from the PDA though, as far as I know there's no head unit that'll control a PDA that's hooked up to it... too many different types and different software.
                Nick
                  thanks nkotch. at least now i have a better idea of how/where the pda should be located in terms of accessing the music on it & being able to see it easily if i have to acess functions on it to control music playing.
                  i'll check palm website again or ask them about using the external connections on their recent models. you see tmy car uses obd-i & the current cable i have uses a serial connector & converter which then connects to the palm's external port. i think it's a propietary configuration. it's not a serial bus nor USB port. i believe most of the recent models are using usb. i do not know of any cable that would work for connecting to my obd-1 connector.
                  hopefully something is out there...
                  & yes, you did state that earlier about pda's having mp3 capability.
                    You can shell out $150 for a PDA that will give you everythign you want. Axims are nice because you have dual card slots. Toshiba e7XX series are also great, plus have the bonues of Wifi at a cheap price. The best idea is to get an x50v, with VGA output, and you can display things on a screen
                    Carputer Progress: Here we go again...
                    THE GF THEME
                    Genesis has speed
                    Genesis has class
                    Genesis sent money
                    before your a__;)
                    Join the fight against carputters. EMAIL ME!
                      Do any of these pda's have serial connection ports (or accept serially transmitted data) for data logging from my car's ECU? i think the OBD-I protocol is to transmit data serially. as i said earlier, i prefer to use a palm unit since i already have the accessories for it (cradle, cable & right-fitting connectors/adapters, etc.). however, i would definitely get another one if it offers all 3 basic things i need (datalog, mp3 player, able external output to another source)
                      i noticed on the list of compatible units a "palm tungsten w". anyone familiar with this unit? i have looked on palm's webiste but they did not show the detail i need. i tried to compare it on pricegrabber too, but they don't even list the unit.
                        Good idea. How about the Palm Tungsten W? It's a PDA phone with a built-in earphone plug and it still uses the standard HotSync cradle/cable from the Palm m500 series handhelds. It's also under the list of supported devices for the MMCd software. I just don't know if it supports MP3 playback. If it does, I'm going for the same set-up.
                          Typically, PDAs don't have serial conenctions. You might find one with a USB connection, which is a serial connection, but you'd need a USB OBD cable. Realistically, I'd look into a bluetooth OPBD reader and a PDA with bluetooth capability (either built-in or available as an additional module). That might be the best solution.
                          I believe that Palms Tungsten line is no longer made. That would explain why you're finding very little about those models.
                          How about the Wiki?
                            Most of the recent PDAs have serials. I'll name a few for you.
                            Dell Axim x*
                            HP iPaq hx*/rx*
                            Palm Tungsten T3/T5/TX/Treo etc
                            Hope this helps.
                            Hmm I think it is little tough to say. Tugnsten's current model is TX, but they target to Treo 600/700 mostly these days. Those phones also have serial available through the Mutli Connector.
                            Car pc integration with ease
                            Car mediacenter
                              i'm not sure about the m series, but i know the tunsten w (TW) will not fit my palm iiix cradle. http://www.pdastreet.com/forums/showthread.php?t=65651
                              & from what i know it can support mp3 files, but there may be some other acessories needed to make it happen?
