Girder cannot enable winlirc device
  • Girder cannot enable winlirc device
    noob question ......i'm using WinLIRC and Girder since i don't have a TS. I have one problem with it. when starting and goes into the front end, there's a error message saying "Unable to open COM1 Port" . it happend everytime i boot up the pc. thinking it might be a hardware problem but it have no problem receiving signal when i enable it again .
    First 3 Version DONE ...but sold ..with the car .. now .. building another one for the new car .
    Coming Soon : CarPC 2.0 .. 40%
    You should use Igor SFH-56 plugin instead of WinLIRC.
    Google for Igor plugin or Igor Cesko which is the name of the author.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      i'm already using igor plugin ..
      already check it .. this only happend when i open road runner at startup. the girder have no problem at all without RR running .
        problem solved ..COM port conflict issue with RR GPS port ...
