Girder!
  • Girder!
    it keeps picking up button presses as the same code
    this is on various devices, i added 3 different media PCs to my harmony remote ad tried 2 different dvd players, on all of them several buttons are the same
    i.e. ff and play, play/pause/stop, skip back and skip forward
    My install... check it out!
    www.mp3car.com/vbulletin/showthread.php?t=56599
    are you using winlirc or what else to tranfer presses to grider?
      i'm using a plugin called Igor
        i don't know much about the igor plugin.. i am using winlirc myself, but this is probably a problem with the "server part" (igor in your case) i had the smae problem with winlirc and changed the EPS value in that and that fixed it..(EPS is a setting in winlirc config)
          can i use winlirc for a serial ir receiver?
            absolutely i have made a receiver succesfully 2 days ago to use my blaupunkt RC10 .. it is peeeeeeeeeeerfect let me know if you need any help.
              cool, i'll try that when i get home
                i've got winlirc but can't quite figure it out
                is it used in conjunction with girder? how? anything else?
                  2001 pontiac firebird
                  hi i am new to this and was just wondering if you knew anyhting about stereos. mine keeps shorting out.....
                    http://www.lirc.org/receivers.html
                    Is you receiver similar to these?
                      winlirc is usually used with girder.. you can use it alone there are many apps that can read codes from winlirc directly..there is a plugin for winamp also...by using that you can control winamp by winlirc only.. girder is more powerful though to control apps
                      check this thread out it has everything
                      http://www.mp3car.com/vbulletin/show...t=rc10+winlirc
                        Try changing plugin priority level in igor config to 8 (I think default is 7 )
                        Y2K Accord Dell GX150
                        EmoRebellion is a SCAMMER
                          winlirc keeps telling me it failed to initialize and would i like to change the config, that would be fine if i knew what any of it meant
                          Matrix - i've got it on 8 now but no change
                          i'm going insane!
                            winlirc always display that msg first time..change your com port to the correct one and then press "learn" so winlirc can learn your remote.. the learning process is quite guided.. although some remotes are very dificult.. what are you using for a remote?
                            EDIT: maybe you can also find a config file ready in here so you will not have to go through the learning process. just press browse and load the file
                            http://lirc.sourceforge.net/remotes/
                              winlirc doesn't show any response from my remote yet i know the remote and receiver work because girder receives signals
                              the remote is a logitech harmony, its a universal remote and so i've been using various devices programmed into it for my commands
