Will there be conflict?
  • Will there be conflict?
    if my laptop only has 2 usb inputs and I go buy it a 4 input usb hub. Will there be a conflict with my key keyboard, touchpad, Gps, and external dvd when all four are plugged into the hub? if so is there a way to fix this or am I screwed?
    ccortes@smscorp.com
    there shouldnt be
    but then again, it would all depend on your system, and exactly what units you're going to plug into it
    but you should be fine
      system is a
      intel 2.8Ghz
      with 1 Gig or ram
      and windows xp
      60 gig hard drive
      anything else you need to know?
      ccortes@smscorp.com
        haha, i meant what drivers are running, and what drivers the stuff u want to put in need
        but again, there shouldnt be any problems with that you want to connect
        edit: might want to take a look at the power usage of the components though, dont overload the hub, or get a powered hub
          aw smart guy yeah i will most definately get a power hub he he. I am power hungry. OK thanks this helped a ton
          ccortes@smscorp.com
