Lilliput 7" Dimensions
  • Lilliput 7" Dimensions
    Does anyone have their Lilliput 7" in pieces right now ?
    I'm trying to find the dimensions of the 'screen only' (The screen without the outer casing.)
    I have a really tight space to work with. It's not quite DD, and I think I might be able to get away with only moving a couple buttons if I don't use the outer case, or shave it a bit.
    The dimensions WITH the casing would mean moving almost all my buttons :s
    06' Mazda6
    Hope this helps
    -Monitor: Height 5" (126mm) x Width 7 3/8" (187mm) x Depth 1 3/8" (35mm)
    -LCD Panel: Height 4 1/8" (105mm) x Width 6 1/2" (165mm) x Depth 5/16" (9mm)
      Prime man, that's exactly what I was looking for. Thanks
