slot-in slim dvd calification...
  • slot-in slim dvd calification...
    just verifying -- im working with a p4 micro atx. going to be mounted in the trunk and ran off of m2atx (bench test runs fine with regular dvd and hard drive.. so i want to mount a slot in slim line in my dash to pull it together. as i understand it the internal ide wont work power reasons. and the external usb will work, so i could either buy....
    http://www.newegg.com/Product/Produc...82E16827106034
    and run the usb maybe to a power hub for power issues or...
    http://www.newegg.com/Product/Produc...82E16827106031
    and
    http://www.centrix-intl.com/?DirectB...source=froogle
    just making sure the 10' usb will work, or if i need to run a powered usb hub - thanks guys.
    I have the first (lite-on) it works so good and it is very beauty... but i have connected it only with a 2 meters usb cable, i don't think it needs a powered hub coz it is powered itself. Just be aware: it needs the power, it doesn't get the power from the usb port! Then with the usb cable you need to run another 12v cable (you may re-use the original drive psu jack, cutting the power cable). Here's mine:
      thanks for the help -- is it possible to cut the power jack and adapt the 12v to the m2atx?
        Hope this helps. Not all slim slotloads are 12V. Mine happens to be 5V. It recieves it's 5V from a modified barrel plug adapter connected to the 5V rail of my PSU and the USB is routed through a powered usb hub. Works just fine on the bench so far.
        http://www.mp3car.com/vbulletin/showthread.php?t=84978
        http://gickr.com/results4/anim_5055e...a2b3b197c9.gif
        1990 RHD JDM 300ZX TT 2+2 5sp T-Top
        491RWHP / 18psi / 94 octane
          IDE would work with convertor. But IDE spec max cable lenght is 3 feet, so if it's in your trunk, it won't work.
            thanks guys im gonna grab the first one, gonna run a 12v rail from the computer.
