Headrest monitor input question
  • Headrest monitor input question
    Hey,
    I plan on using a laptop for my carpc with a xenarc 7000tsv screen. I was wondering if i got headrest monitors how would i get video to them?
    http://www.mp3car.com/vbulletin/show...19&postcount=6
    It's post #6 in the Newbie FAQ
    How about the Wiki?
      I'm sorry i still don't understand, let me try to clarify my position.
      I have a dell 600m as my carputer that connects through vga to my xenarc 7000tsv. I'm trying to get that same video feed into a headrest monitor. However, the headrest monitor accepts only rca video input, and thus my dilemna.
      thanks
        Ahhh.
        You need some device to clone the signal, I believe.
        How about the Wiki?
          I have s-video on my laptop; i think i can use it to convert to rca. My other question would be how many times would i be able to split the signal before it would be not very clear?
            All you need is a cord that has the 4 pin s-video on one end, and the rca on the other. I picked one up from what used to be radio shack up here canada. then you just set it in the displays section to clone the desktop from your primary monitor.
            Keep in mind that if you do more than 2 monitors on the same, you will most likely need a video amplifier, you can get one from www.MP3playerstore.com
            Here a pic of my set up to give you an idea.
            "the universe has a way of balancing itself"
            http://i15.photobucket.com/albums/a3.../Webbanner.jpg
