wiring a power switch to laptop
  • wiring a power switch to laptop
    okay i took off the cover over my on button for my laptop compaq v5000, it looks like there are 4 points i can solder wires to, how do i find which points to solder the wires too?
    take a look at the stickey:
    http://www.mp3car.com/vbulletin/lapt...er-switch.html
      two options:
      1. with the laptop off, remove power cable and battery. use a multimeter to test which points to solder.
      2. with the laptop off, use a wire as a jumper to short out 2 points at a time. when the laptop turns on you'll know which points to solder.
      F150 Truckputer [1.0] (coming soon!)
      Fusion Carputer [2.0]
      Fusion Carputer [1.0]
        Re: Note
        Note - You need to physically press the button to check the contacts with a multimeter.
