Noise interference from auto air adapter
  • Noise interference from auto air adapter
    After hearing what people had to say about using an inverter vs an auto air adapter, I decided to take my inverter out and replace it with an auto air adapter made specifically for my laptop. Here's my setup:
    IBM T42 thinkpad
    Port Replicator II docking station
    1/8 audio out to RCA plugs - connects to aux in on my head unit.
    When everything was powered by an inverter, I got no noise or screen interference at all. The only noise I got was the little fan on the inverter which keeps the inverter from overheating.
    After switching to the auto air adapter, I noticed a few lines of interference during bootup on the screen, and noticeable noise interference when I bring up road runner. The noise interference is like a wave, fades in then fades out repeatedly. When I play an mp3 which is a ballad, it becomes more noticeable.
    I read threads where people were having the opposite effect, interference with an inverter but none with the auto air adapter, but never the other way around. The only change I made was the adapter. My question is, is anyone else experiencing this, and if so, what could be done to suppress the noise interference?
    Okay here's an update. After reading more threads on how people were using a ground loop isolator to solve their noise interference problem with an inverter, I decided to try it with my problem with the auto air adapter.
    Results? It seems to have worked like a charm, noise interference is gone! The one I used is from best buy for $17.99 although you can find cheaper ones elsewhere.
    The isolator has male/female rca plug connectors along with two wires that need to be grounded. I just grounded them to the same place my head unit is grounded.
      hello , what adapter you used , what is the number parts on best buy , thanks
        I bought this one:
        But you can find a similar one at radio shack or circuit city for cheaper.
        I connected it between the aux input jacks of my head unit and the cable which has rca plugs on one end and a 1/8 plug that goes to the headphone jack of the thinkpad.
