Please feedback about my screen.
  • Please feedback about my screen.
    Hi.
    My names is Bengt and I'm currently in the planning stage of my first build, and wanted some input from you guys.
    I have an old Sony Vaio (VGN-FS195VP) that I'm going to use together with this screen: http://www.deltaco.se/article_inform...?ItemID=TV-703 (PDF)
    Is it a good screen ?
    Is there anything i need to know about power consumption?
    Can i power this directly from the car's 12V or do i need a converter of some sort ?
    I live in Sweden and don't have the stuff you are discussing near by, so i have to grab what ever i find.
    Hope to get some feedback from you.
    And I have a ton of questions later on.
    Hmm over 50 views and no comment.
    How come it so hard to make a comment, was the questions to hard ?
    Come on guys, I really need your expertcomments.
      That screen looks a lot like the Lilliput 629GL. But without the Lilliput badge.
      http://store.mp3car.com/2008_Lillipu..._p/mon-016.htm
      It is an OK screen but it may be horrible in sunlight.
      You can run from car ACC line OK, it will have a voltage regulator on the cigarette 12v powercord. You can cut off the cigarette plug connector and wire direct to car voltage or OPUS power supply whatever your have.
      Have a search around for Lilliput installs.
      Good luck with it all
        Yea, the Lilliput is almost exactly the same, but alot cheaper.
        I have the oppertunity to return it to the store if i'm not happy with it, so i think i have to buy and try.
        You can't buy Lilliput here in sweden, not that i know of anyway.
        Thanks for the input.
        /Bengan
