how much heat will this kind of motherboard produce?
  • how much heat will this kind of motherboard produce?
    i was looking around the web and stumbled upon this motherboard. i think this is for a laptop, right? would this kind of motherboard produce too much heat? or will this work well for a carputer?
    i assume, it produce no heat, because its invisible.
    Jokes aside, post model number.
      Full grown, FYI: Its best to post as much info as possible when inquiring about a specific product. It may get you better results.
      If you cant DODGE em, RAM em.
        ohh crap... i'm dumb...totally forgot to post the link...
        http://www.newegg.com/Product/Produc..._-NA-_-NA-_-NA
          Damn... why would you need that much processing power?
          That will be power hungry and need lots of cooling, my view for what it is worth.
          Keep in mind, my preferred system is small, much lower power, and much lower heat.
          cheap to power, still does what I need, hides well and easy to cool.
          TruckinMP3
          Read the FAQ!
            this is laptop section... this should go in hardware...
            2008 Civic... Sound system... then carputer install...
            WORK IN PROGRESS
            If you look at my avatar closely, you can see a chick with two big knockers....
              You can easily go with mobile components rather then desktop. Mobile will have less power draw. The heat though will still be an issue. As long as you have good cooling then your fine.
              1X Ainol Novo Flame Tab
              4X MK808b
              3x Perixx Touchpads
              3x 7 inch Screens
              1X 7 inch motorized Screen
              1x Win 7 PC
                No.
                I'm curious to know what makes you think this could be a laptop board.
                Typically, end-users can't purchase a laptop motherboard.
                Motherboards don't produce heat. CPUs produce heat. You can choose a CPU that doesn't produce a lot of heat or you can choose one that will not only play your MP3s, bu also act as a warmer for your pop-tarts.
                Research will help you determine a CPU that will produce less heat.
                I agree with the assessment of others. This board is some serious overkill for a car install.
                It will make a fantastic gaming rig. But gaming rigs suck power like no tomorrow. High power draw is not what you want for a vehicle installation.
                How about the Wiki?
                  i know this one is not a laptop motherboard. but saw this on an ad. sorry i'm not good with computers. don't know what's what, and what's good for a carputer. i'm just trying to find out things. but how about this one? http://www.buy.com/retail/product.asp?sku=208661725
                  too much? what do you guys think?
                    That's an infinitely better choice for a car PC.
                      Just browse through the mp3car store... thats all good choices for CarPC hardware.
                        First of all, heat can be remedied. What do you want to do with this carputer?
                        Give us as much info so that we can provide you with good answers in determining your needs.
                        Check out my CARPC: Project Diamond Plate
                        Quick Reference:
                        CPU Electrical Specs
                        Power Supply Calculator
                        Video Connections for newbies
                        Temperature Converter
                        Voltage Calculator
