Laptop CarPC people respond!
  • Laptop CarPC people respond!
    How do you power up and down your laptop carpc on car on and off? Thanks!
    Power Up: Press the power button. (You may want to extend it from the laptop's motherboard)
    Power Down: Go to Start --> Shut Down --> Shift+H to Hibernate or U to Turn off
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
      Startup: Have a switch in my dash wired to the power switch on the laptop. Press it to turn on, or resume from standby or hibernate.
      Shutdown: Press switch to go to standby(or off depnding on settings). Or when I turn my car off power is cut and I have it set to go to standby 6 minutes after it loses external power.
        Try a DSSC for startup.
        Shutdown is automatic via power settings as others have noted.
        -arebelspy
        See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
        Originally posted by xdjxklusivex
        i think every thread is now a whoreing thread
          is it difficult to wire a switch from the button on the motherboard? Im a newb
            Search the forums. Someone posted a good guide for their laptop complete with photos. It should be similar for any laptop.
              I use a full opus 150 setup with my laptop board.... starts it & shuts it down.... powers all my accy.'s & usb with room to grow...... a little overkill, but I had it from my previous install....
                I read somewhere that it is possible to set some notebooks to 'wake on ring' and use a hacked phone cable plugged into the modem port. Shutdown would be set on loss of external power.
                A quick search for 'laptop wake on ring' got me:
                http://www.mp3car.com/vbulletin/show...ptop+wake+ring
                http://www.mp3car.com/vbulletin/showthread.php?t=15320
                There are more...but the above should give you enough to get started.
                personally, I think the wake on USB option sounds interesting. Plug in a trackball & press a button to start the laptop. Depends very much on the capabilities & bios of your laptop.
