Basic questions about android as carcp
  • Basic questions about android as carcp
    I found a few other topics, but still feel the need to ask these questions here.
    I think that ideal implementation would be for android tablet as all on one while car stereo would be just volume control. So required functions for me would be: good music player, gps, handsfree phone.
    So here are my questions:
    1. how to use android tablet as bluetooth handsfree for my phone? Is it possible jet?
    2. is it possible to use my phone as access point for android tablet to internet at same time?
    3. how to make it power on and off with ignition? Power off should be preferably delayed with tabled running on battery for a few minutes.
    4. can it work with usb or bluetooth gps receivers?
    5. is it possible to use some launcher for carpc apps (navi, music, phone, ...) after start instead of android default desktop?
    Im currently working on a project to make an Android tablet much more car friendly and easy. So here is what I can say about your questions:
    1. Not sure on this one and doing some research into so will get back to you on that
    2. If you mean use your phone as a mobile hotspot then yes this is possible depending on your phone carrier, all tablets have wifi capability so this is relativily easy to set it up to auto connect when in range.
    3. there are some apps out there that allow you to do automation with certain events like being plugged in or hitting a certain time, I havent gone into too much depth with these apps but I have seen them, I quick google search and you should be able to find something. To make it work you would add an event to shut it down when power it is unplugged (aka the car dock/charger isnt getting power) turning it back on though would be a little more difficult since the app isnt running
    4. this is kinda a mute point depending on the tablet but I have yet to see an android device that doesnt have built in gps (and the android software comes with a turn by turn navigation built in) the only downside to this is you need some kind of internet connection to load the maps for the navigation (though getting lat/lon and general data from GPS is still capabale without it)
    5. Yes!!! as this is the main focus of my current project (see my thread about an Android frontend in the forum) I am currently making an app which simplifies and makes using the android device much more car friendly.
      there are bluetooth GPS recievers that should work with android devices, there is also an application that allows you to tether the GPS from your android phone to another android device.
      i'd like to know about the handsfree information as well, i've researched but haven't been able to find anything, i can't even get my phone and my tablet to connect via bluetooth so at this time i doubt it.
      you can tether for internet but some devices lock out adhoc networks meaning you wont be able to use your phone as a hot spot, there are software workarounds however they are for advanced users.
      i've used 2 automation programs that are pretty good are called automateit and tasker, they are both pretty good but only one of them is free. there are a few car front end applications out there but they are not very full featured yet. that should change pretty soon.
      for now i would recommend beautiful widgets for large customizable homescreen time, date and weather. torque for ODBII information, and the 2 previously mentioned automation apps. also do a search for car home and you'll find some front end programs.
        I'm going to guess no to number 1. Android is a smartphone OS primarily and doesn't have any use-cases where it won't have a modem in the hardware.
        Former author of LinuxICE, nghost, nobdy.
        Current author of Automotive Message Broker (AMB).
        Works on Tizen IVI. Does not represent anyone or anything but himself.
          Haven't found a way to do this yet
          Yes, wifi tethering
          You shouldn't need it to power off and on, I use Tasker on mine so when the car is turned off, ie. USB not charging, the screen timeout is set to 5 seconds and the screen turns off. When the car turns on, the screen instantly turns on and starts playing music. My drive to and from work is only 15 minutes each way, but that is enough to fully charge the tablet from it sitting idle the rest of the day.
          But yes, with Tasker you can set the tablet to power down, but then you'd have to wait for it to boot when you turn your car on, unnecessary.
          I've heard some can, but you can't be sure, better off buying a tablet with gps built-in
          I use LauncherPro and I think I have a pretty sweet front-end, large stylish icons, and can change them anytime I get bored with them. Check it out, links in my sig.
          Android Tablet In-Car Sliding Dock using hacked DVD drive
            BT-GPS works
            Bluetooth external GPS receivers work perfectly with android in combination with; BlueGPS4Droid
            http://forum.xda-developers.com/showthread.php?t=833094
            It uses the android API - Mock Locations.
            One sidenote. Sygic and NDrive both reading the NMEA hardware instead of using the android GPS API. Because of that, both Sygic and NDrive software packages don't work
            Tested iGO, CoPilot and Navit. All three work! (Navit is free and opensource)
              Thank you very much sir, that is what i needed to know. I wanted this because it gives everyone much more installation options. Also in my car it is very hard to get gps signal almost anywhere in front because of glass thick glass.
              Now bluetooth handsfree is only thing i would like to have to have all in one solution.
              Also is it only possible to tether for android using WiFi? Can i also tether using blootooth? My iphone like so tether trough bt more then trough wifi
              That seems to be enough, at least as a start. I would like to install device in dash so i don't know how accessible power button will be - but in a worst case i can probably wire up the switch for power button on the device somewhere.
                I am Dutch so... Tasker is a bit expensive (worth it tho!). You can first try out "AutomateIt", it is free. (https://market.android.com/details?i...=search_result)
                I use it to maximize the volume, turn on bluetooth and run BlueGPS4droid when the tablet is forced into car mode.
                You can for instance make a delayed task "shut off when not on charger". If you turn of the car and therefor the carher is disconnected the tablet goes off after a certain delay.
                How to turn it on without a power button is the next question?
                  Also sound priorities is another questions so BT handsfree (when it will be possible ) would be priority 1 then GPS as second and mp3 player last. well android is still quite not here jet
                    I don't think you number 1 will work below Android 3.0 as all Android version are supposed to be phones. Why use a phone to connect to a phone?
                    With a real tablet version of Android which are here already as Honeycomb, this is might be solved with some extra packages. I don't own a honeycomb tablet so can't look at it for you.
                      I take it you haven't seen http://android-x86.org/
                        A couple of days ago I decided I wanted to replace the head-unit in my 2005 Civic with a Galaxy Tab. I'm waiting for the new generation of Tabs to come out so that I can an older tab at a nice discount.. but, I figured I should do all my homework before I buy the tablet so that I'm ready to go once I do purchase the tablet. Most of my questions were answered in this thread but there was still one outstanding item that I would really appreciate some help on:
                        * How will the tablet interface with the car speakers? I've done a little bit of reading on this and it sounds like I will need to install an amp? It would be super helpful if someone could point me to some detailed instructions on this or simply let me know what I should buy... I've been relatively happy with the sound quality in the car right now so I'm not looking to break the bank with a new amp. Also, is there some sort of equivalent of "line-out" for the tablet or should I control the volume from the tablet since the car will no longer have a volume dial?
                        Thanks in advance.
                          I just bought a Nook Color for $200 which I promptly rooted and installed the latest stable build of CM7 on. I am planning on putting this in my double din bay on my dash. If you want an inexpensive tablet with most capabilities and great value for the price, the Nook Color after rooting and romming is your best bet.
                          My biggest question right now is the power (but I think this thread helped me answer it with the AutomateIt app), and how to interface the audio.
                          What I'm looking for is an amp that's good enough to keep my stock stereo sound quality in tact. I don't need anything fancy. I'm thinking 400w. I also want to minimize wiring hassle and put the amp right behind the Nook. I don't know if such a small amp like that is made anywhere, though.
                          For connecting it, I'll be using a 3/8ths to RCA adapter.
                          Anyone have thoughts about the amp?
                            I have the same basic setup with my streak 7 in a double din bezel, a little custom work was needed. For power I just used a cigarette lighter adapter and hardwired it to my stereo power using a stereo adapter harness. As for an amplifier I'm trying to find one myself, I would check out the alpine power pack and the lanzar mini amp, I cant remember the model. There us another one like it that is only sold in the uk.
                            http://www.google.com/m/products/det...ed=0CCYQ8wIwBA
                            http://www.google.com/m/products/det...ed=0CBUQ8wIwAA
                              1. how to use android tablet as bluetooth handsfree for my phone? Is it possible jet?- I think there is some confusion with this question but imma take a stab at it and assume you want to make calls from your tablet. This depends. For CDMA (Sprint/Verizon) this will not work....unless... you do what I did and setup a sip and ipkall account then integrate with your googlevoice account...VIOLA! I can make and receive calls with my Verizon Galaxy tab. More details here: http://forum.xda-developers.com/show....php?t=1150727
                              2. is it possible to use my phone as access point for android tablet to internet at same time?- hmm... if you have a newer smartphone which these days can also serve as a mobile hotspot..why do you need an access point again?
                              3. how to make it power on and off with ignition? Power off should be preferably delayed with tabled running on battery for a few minutes.- So here is my experience and thoughts on this. I think a new shift of design is required for these types of tasks and mobile devices. Also i don't believe should to be confused and subjected to the crazy complex ways of other "mainstream" carpc solutions (using mini-ITX mobo builds, etc). I can keep my tablet on for over three days and I have plenty of battery still left. This includes me using music, GPS, internet music streaming. I think that as long as you have a power source for charging your tab in your car (USB to Cigarette) then you should be good to go. I just take my tab inside with me for the night if I want or need to charge, but it holds a charge for quite a while and charges also in my car when mounted. But, not all tabs are created equal. Worse case you power your tab on as you are walking to you car and its all ready.
                              4. can it work with usb or bluetooth gps receivers?- This depends...if you get a tablet through a mobile service such as verizon, sprint,etc then you can just use that because they have gps. If you get one of those very affordable ones from ebay, you have to really read the features because again not all android tabs are created equal..
                              5. is it possible to use some launcher for carpc apps (navi, music, phone, ...) after start instead of android default desktop- Sure. Check out the market. There are a few to try out. Here is one for example: https://market.android.com/details?i...=search_result . The cool thing about android though is if you have the skill (and maybe you do not really need much) you can build your own app or launcher: http://appinventor.googlelabs.com/about/
                              Whatever you decide I think these forums are the best ever and members will provide some awesome and intuitive ideas on solutions that may fit your requirements.
                              "Live Free!!!...It's all about Open Source"
                              Recent Proj
                              Old Proj II
                              Old Proj I
                              YouTube:Project Videos
                              Homepage: HexxWorld.net
                              Twitter:http://twitter.com/hexxamillion
